Taotao 150d not starting
Old Apr 11, 2010 | 02:33 PM
bigredquad's Avatar
Question Taotao 150d not starting
So it started up fine. I let it warm up for a litte while. Then rode it maybe 100 ft and it started bogging down and then shut off. I thought i was out of gas so i poured a full tank in. It still didnt start. I took off the carb and cleaned it. And still nothing. Its getting good spark and fuel in some of the lines. But i dont
think its getting fuel to the spark plug. Any ideas on what could be wrong?
Old Apr 13, 2010 | 09:14 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Welcome to the forum bigredquad!
If your still using the stock spark plug Id get a NGK C7HSA... Do you have a fuel filter on this quad?
Old Apr 13, 2010 | 06:16 PM
bigredquad's Avatar
Yes i have upgraded to an ngk and i dont have a fuel filter on it right now but i plan on using one if i can get it running.
Old Apr 13, 2010 | 06:20 PM
KTM Patrol
Former Chinese POW!
With no fuel filter youve more than likely got sand in your carb again..
Old Apr 13, 2010 | 07:23 PM
bigredquad's Avatar
Yes thats what i figured so should i take the carb off and clean it again.
Old Apr 13, 2010 | 08:59 PM
LynnEdwards's Avatar
Electrical Expert
Could be a clogged carburetor, but another thing to check is whether you are getting fuel to carburetor at all. Unhook the fuel inlet line to the carb and direct into a bowl. Let it flow for a bit. Is the stream steady or does it slow to a drip, drip, drip?
Both I and my neighbor have had our quads exhibit the same symtoms you describe due to defective fuel shutoff (petcock) valves. Mine was defective from the get go. I'd start up the quad and go about 1/8 mile before it bogged and shut down. My neighbors failed after two years. On his, the gasket between the rotating cylinder and the shutoff valve body rotated and almost completely blocked the fuel supply. Same thing. Let it sit and it starts up. Drive a bit and it bogs and shuts down.
Old Apr 26, 2010 | 06:07 PM
bigredquad's Avatar
I squirted a little fuel in the spark plug cylinder today and it fired up then shut back off. I kept doing this until it finally fired and ran for about a minute then shut back off. Then tried it again and it immidialty shut back off again. I now think the floats are sticking. Any more suggestions? Thanks
Old Apr 26, 2010 | 07:58 PM
mikel1's Avatar
Sounds like the fuel system needs a real good cleaning from the tank to the carb. Did you drain any old fuel out of the tank, thinking it may have some water in it.
Old Apr 26, 2010 | 08:35 PM
bigredquad's Avatar
Yes i had been using premium and i thought that could be the reason so i drained it and put in regular.
MikeyBoyesq
Nov 27, 2020 02:44 PM
garyt1975
Jun 5, 2015 08:53 AM
hugemoth
Jun 4, 2015 02:56 AM
1000gade
May 27, 2015 12:37 PM
elmer119
May 24, 2015 10:51 AM
