Advice on TAOTAO 150cc Automatic
Old Apr 12, 2010 | 09:07 AM
CodemanX's Avatar
Default Advice on TAOTAO 150cc Automatic
Hello Everyone! Since I am new I hope I am not duplicating this question. I did look around but was not able to find my answers.
My questions is regarding the Automatic trans. When you are at a stop and hit the gas will the machine move quickly off the line? Or is it a lot like a go cart?? Lot of noise and no go. I am concerned if I get one of these would it be able to accel up a hill from a stop.
Hope someone can help me out..
CodemanX
Old Apr 12, 2010 | 11:44 AM
OneTenCC's Avatar
I've never run one of these, but from what I've read, they seem like the best setup going for the gas-n-go, "automatic" crowd. They operate as a CVT as opposed to a single speed centrifugal clutch like the ~125cc and under have. This type of CVT should give you better RPM/ground speed control. Inside the aluminum case is a belt, then a chain from the output to the sprocket on the rear axle. The engine is fan cooled, so it should cool more efficiently at low speeds.
Old Apr 12, 2010 | 04:57 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Welcome to the forum CodemanX!
It isnt neck snapping power, but its not like a centrifugal clutch go cart...both of mine accelerate as fast as my 200 and while neither of mine will do wheelies, both will climb hills they have no right being on... not fast but lots of low end pulling power..
Old Jun 8, 2012 | 12:48 AM
Richard Graham Poster's Avatar
Even at part throttle it will get up to full speed without revving very high.
Old Jul 29, 2012 | 04:02 AM
midlifekrisiz's Avatar
we put a bigger (3 tooth) rear sprocket on the wifes 150 cc gy6 and she followed me up some steep rocky terrain just the other day ....was surprised she did it but she said she had not problems whereas before she would have had problems.
Old Aug 1, 2012 | 10:34 PM
RonV's Avatar
If it is a GY6 based motor/trans, then there are all kinds of ways that you can tune the trans on that to make it the way you want it. Its a very reliable transmission.
Old Aug 2, 2012 | 12:42 AM
Jaster94's Avatar
they're great. i've had quite a few of them. i'm not a centrifugal clutch kind of guy anymore. i like the CVTs.
ultangler
Nov 30, 2024 01:35 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
dannytas
Sep 26, 2017 06:31 PM
kodiacrunner
Oct 4, 2015 11:52 AM
