110cc Jcl carb float not working
Old May 1, 2010 | 11:30 AM
bjreed1999's Avatar
Default 110cc Jcl carb float not working
Hello all
Thanx for the quick fix to my gas tank problem
My next problem is that the gas is draining from the carb when installed. I have cleaned/sprayed all the jets. I believe the problem is wiht the float . it operates properly and everything looks brand new. I have adjusted/checked the float several times and its still leaking. With an extreme ajustment to close float it almost stopped leak which tells me float is working, but not seating? I did not see a seat for the pin. Does the rubber tipped pin just seat into carb housing or is there an oring that may have fell out. Any help would be appriciated!
Old May 4, 2010 | 02:30 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
The needle seats into a brass fitting.. if both are clean and the float is adjusted correctly...(most floats appear level when upside down)..and it still leaks, the needle/seat could be worn out.
armpump450r
Technical and How-To Articles
Apr 1, 2017 06:11 AM
Dame0927
Oct 29, 2015 10:13 PM
Spokes
Jun 22, 2015 08:02 AM
garyt1975
Jun 5, 2015 08:53 AM
kevbowe
Jun 1, 2015 01:17 AM
