Transmission trouble
Old Jun 3, 2010 | 12:30 PM
jesse8james's Avatar
Angry Transmission trouble
i have a automatic e-ton yukon cxl 150 atv it was running fine but then i was riding and let into it it started to make this really horrible grinding noise like gears grinding it only happens from stop to take off and when i let into it i have no clue what is wrong with it can somebody help?
Old Jun 10, 2010 | 06:38 PM
Eric Schoembs's Avatar
Default Same Problem
I am having the same problem with a Tomoto HiSun 500s and I was told that the first step is to try changing the oil as the oil lubricates the transmission.
Eric
Old Jun 10, 2010 | 07:58 PM
yea i already did and still doin it
Old Jul 26, 2010 | 07:42 AM
Default did you find a fix??
Did you find a fix for your tranny problem???
Eric
Old Jul 30, 2010 | 05:43 PM
no i didin't and its killing me lol just wanna ride
Old Jul 30, 2010 | 06:16 PM
Jaster94's Avatar
here's some stuff on Eton:
http://www.anythingatv.com/Technical...NNYGEAROIL.pdf
does it sound like it's inside of the case? did the oil have metal shavings in it? if a chain drive, have you checked the little drive sprocket to see if the chain is slipping? i'm not familiar with your quad at all, but if it has got a centrifugal clutch, is it slipping? i'm trying to help ya! bear with me.......
Old Jul 30, 2010 | 06:27 PM
yea it sounds like its inside the case i think i chipped a tooth on the drive gear..... sucks
Old Jul 30, 2010 | 06:32 PM
Jaster94's Avatar
well, it sounds like that? i just read the owner's manual online, and apparently it is V-belt driven so i presume that would mean centrifugal clutch, (i'm not a tranny man). sorry i couldn't help you anymore. they'll be a tranny expert come along shortly to see this post and help you out. see ya'
Old Jul 31, 2010 | 07:21 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Welcome to the forum jesse8james!
Sorry for missing this post. Your 150 has a CVT which is belt driven but it also has gears.. The rear of the CVT has its own gear case. The part that the drive shaft sprocket comes out of.. It has 4 gears and has 90wt gear oil in it... you will need to take it apart and find the bad gear and or bearing..
Old Dec 21, 2010 | 08:26 AM
kheier's Avatar
Default tranmission trouble
i had the exact problem with mine and it is the drive gear assembly in the transmission.......if you are very mechanically inclined it is a simple fix. but you must take the trasmission case apart and replace the drive gear assembly (and gasket) total parts about $70 and about 3 hours to take apart and replace. just make sure to get it all put back together right the first time i had to do it twice since i overlooked a couple of mount bushings as i was putting it back together
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
mrtidy
Feb 3, 2016 05:00 PM
r1pilot83
Sep 27, 2015 07:38 PM
Clint Russell
Sep 25, 2015 03:20 PM
WilliamBos
Sep 22, 2015 04:07 PM
