'07 hi-bird 250 carb idle problem
Old Jun 20, 2010 | 04:46 PM
Jaster94's Avatar
Default '07 hi-bird 250 carb idle problem
here's the problem: 2007 hi-bird 250. doesn't idle. it starts right up and immediately revs itself up to maybe 1/4 to 1/3 of throttle. will not idle down. plenty of throttling up though. here's some pics. i've read posts that said to adjust the right hand side screw that has a spring on it-tried that-doesn't do anything(maybe cable problems?). took 2 pics of little screw on engine side of carb-don't know what that does-maybe someone knows?! one pic shows a screw that is, what i believe, just a mounting screw for the choke cable mount. hope these pics turn out. the throttle element inside the carb is installed correctly-maybe my cable is stuck and won't release all of the way down to let it idle, eh? maybe i ought to replace it?
BTW, it was sitting for 2 yrs dissambled. this was the one a buddy of mine gave me. i've been working on it for 4 days and just got it to fire up today after church.
please forgive me, all i had was a screwdriver to point at the places!
Old Jun 24, 2010 | 09:16 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
In the top pic... your pointing to your idle adjustment screw.
In the next pic.. it shows the fuel mixture screw which is also iwhat your pointing at in the last pic..
The 3rd pic shows the choke bracket mounting screw... the cable would attach at the top of that bracket..
Id clean the carb but would also check to see that the slide is installed correctly... if its not installed correctly it doesnt drop all the way into its bore..a high idle would be the result.
Old Jul 16, 2010 | 04:16 PM
Jaster94's Avatar
Default hibird carb slide position
ok, still working on this hibird 250, finally got a pic of the slide. is it supposed to go all the way down or does this pic show the correct position? i know it's in correctly, the other way lets it down no where near this position. therefore, i know it's in correctly. 50/50 chance, eh? ha ha.
anyway here's the pic. thanks......
Old Jul 18, 2010 | 02:09 PM
KTM Patrol
Former Chinese POW!
It does look a little high but that can be adjusted by the screw your pointing at in the top picture.
Old Jul 30, 2010 | 06:12 PM
Jaster94's Avatar
ok, i did the advanced needle adjustment inside the slide, now it idles normally and i've gotten it to richen up on the mix, now i need to tear it apart again to clean the jets one more time because now it chugs/bogs down when at full throttle. i'm thinking the jets are plugging off unless i'm missing something. whaddya think?
i will keep you up to speed.
Old Jul 31, 2010 | 07:41 AM
KTM Patrol
Former Chinese POW!
The needle adjustment has no effect on idle...its for 1/4 to 3/4 throttle or so..
Try this... run it at full throttle(2nd or 3rd gear maybe) and without letting off the throttle.. kill the engine with the kill switch, pull in the clutch, and coast to a stop.. pull the plug and look at it.. if its white your lean.. if its dark or black your rich...
Also do you have a fuel filter? Still using the Chinese spark plug?
Old Aug 20, 2010 | 10:06 AM
Jaster94's Avatar
mywifesquad, thanks so much for the help. this sucker runs great now! i had a few misconceptions about the needle adjustments and the rich/lean mixture screw. thanks for the education. i've learned a tremendous amount with this quad. i'm thankful for all of the numerous posts on this website. a lot of people read them and learn from them. i know i do. thanks again. now, for the next project...........
Yamaha_
Utility ATVs
Dec 16, 2022 07:49 PM
JBibb
Jul 4, 2015 10:16 AM
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
