Brain box/Hibird
Old Jul 8, 2010 | 04:24 PM
kromedirt's Avatar
Question Brain box/Hibird
Hi, I am kinda new to this whole forum thing so please bare with me. I am looking for a brain box for a 2007 hibird QH-250STW. Where do I look? I've googled and googled and that's how I found this site, but am still at a loss about the box. It seems I can find sites that sell the atv, but none that give me parts answers. Please help...that's me scratching my "brain box"...lol...I'm guessing noone has any advice for me...it seems I've been viewed by a few people, but no responses...I really could use some help here! Please..
Old Jul 8, 2010 | 07:13 PM
Jaster94's Avatar
here ya go. look for the parts menu to click on.
atv parts, atv accessories, atv accessory
http://www.anamcycles.com
http://www.scooterdomain.com/ATV_s/3.htm
Old Jul 9, 2010 | 12:08 AM
LynnEdwards's Avatar
Electrical Expert
Jaster94's response is fantastic. Lots of good parts in those links.
Your term "brainbox" has me a little confused. I'm wondering what exactly you are referring to. There are no computers or "brains" on stock chinese quads. There is a CDI module [(C)apacitive (D)ischarge (I)gnition]. Is this what you are referring to?
If so, you need to find out if you have a CD or AC powered CDI.
I'm leaping forward here. Correct me if I'm wrong . Why are you wanting to change the CDI?
Old Jul 9, 2010 | 07:55 AM
kromedirt's Avatar
Originally Posted by Jaster94
thank you very much...that was quite helpful..
Old Jul 9, 2010 | 08:13 AM
kromedirt's Avatar
Those are good questions...I'll have to get back to you with the answers. Thanx for the response.
Old Jul 9, 2010 | 09:42 AM
kromedirt's Avatar
Apparently they have a new wiring harness, but still aren't getting any fire. So they thought it would be the "brain box". I gave them the info you gave me and they are going to get me more info so I can order the right part. Again, thank you so much...Why did you ask why it was being changed? Is there something else I should know?
Old Jul 9, 2010 | 08:55 PM
Jaster94's Avatar
Default not a problem
i've gotten more industrious on my web searches. everytime i find something new, no matter what brand of atvs, i put it in my favorites. there's gotta be a law against how many favorites i can have, eh?!anyways, it's just info to pass along to help out the next guy/gal. see ya'
Old Jul 9, 2010 | 11:28 PM
Electrical Expert
...Why did you ask why it was being changed? Is there something else I should know? ..
Good question. There are many things all involved together with quad ignition systems. All these things have to work or you don't get spark. Some of these things can be measured, and some cannot. So the best way to troubleshoot no spark problems is to measure what you can, fix any problems that show up, then if all else fails start changing those things you can't measure.
The center of the ignition system is the CDI. It requires a power supply feeding it (which could be AC [from the stator] or DC [from the ignition switch]), and a trigger signal to tell it when to fire [from the stator].
The output from the CDI goes to the coil, and the output of the coil goes to the spark plug.
On most quads the CDI is enabled, or disabled, via the kill switch input pin. Most "no spark" issues have to do with kill switches, or kill switch wiring. Hence my question about why you are changing the CDI now.
The power supply to the CDI can be measured with a meter (whether it is AC or DC). The trigger input to the CDI can be measured with a meter. The kill switches and wiring can be measured with a meter. Some aspects of the CDI output can be measured with a meter. Some coil parameters can me measured as well.
Measuring the above items is where I'd start. Just changing the CDI is another approach. It might work (and hurrah! if it does), but the odds are against you.
So is you CDI AC or DC powered? Check this thread out and see if your CDI is the same, and then how to tell between DC and AC CDI's:
http://forums.atvconnection.com/chin...se-stator.html
This is just a start of course, but the results of each test tell us where to go next.
Old Jul 10, 2010 | 08:34 AM
kromedirt's Avatar
thanx man...
Old Jul 10, 2010 | 08:38 AM
kromedirt's Avatar
Good question. http://forums.atvconnection.com/chin...se-stator.html
I sure appreciate all this...I will get more info from the owner of the bike by next week...maybe by then he'll have it figured out...your info sure helps though...thanx again...have a great weekend.
firsttimerider
Sep 26, 2015 01:49 PM
HRbart
Oct 11, 2003 11:11 AM
raptorron
Aug 26, 2003 10:45 PM
fishbones
May 17, 2001 11:03 AM
SP500inNS
Aug 3, 2000 07:27 AM
