Redcat vx-80 Carb problem
Old Jul 11, 2010 | 11:24 PM
reckleys's Avatar
Default Redcat vx-80 Carb problem
I just got a redcat vx-80 given to me. It will not start/run. I changed the plug and took out the air filter (just to test). I took the big hose that was connected to the air cleaner off and sprayed starting fluid into the carb. The engine turned over briefly. Since then I can't even get it to start with the starting fluid. Any help would be appreciated. I am unable to find a choke on it...........
Thanks in advance,
Old Jul 12, 2010 | 08:21 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Welcome to the forum reckleys!
Id think your carb needs cleaning..
Old Jul 12, 2010 | 08:25 AM
reckleys's Avatar
Default Carb Cleaning
I wouldn't mind replacing the carb..... However, I have been unable to find one online that resembles mine (my carb does not have a choke). How can I be sure that whatever I order online will work? I have no experience with cleaning carbs or adjusting them. Looks easy enough to take off though......
Old Jul 12, 2010 | 09:57 AM
KTM Patrol
Former Chinese POW!
Cleaning is fairly straight forward... but intimidating the first time..
Could you post a pic of your carb?
Old Jul 12, 2010 | 10:31 AM
reckleys's Avatar
Default redcat vx-80 carb cleaning
Yes I can post one but I am at work so I will have to do it tonight..... Does it make sense that there is no choke? Also, when I looked at the carbs online, they all had chokes and most had the throttle cable enter from the top. This has the throttle on the side.... If you are sitting on the seat facing forward, the throttle is on the right side of the carb.....
Old Jul 12, 2010 | 11:24 AM
KTM Patrol
Former Chinese POW!
Are their any wires going to the carb? (electric choke)
My Yamoto 150 came with a electric choke and the cable mounted to the side on a sort of wheel..
Old Jul 12, 2010 | 11:27 AM
reckleys's Avatar
maybe, I'll take a look tonight....I know that on the opposite side of the throttle there is a black plastic cap that looks like it may be cracked or broken....that might have a wire going to it.....
Old Jul 12, 2010 | 11:40 AM
reckleys's Avatar
I might try and run home on my luch to get a pic......
Old Jul 12, 2010 | 01:38 PM
reckleys's Avatar
Default carb pics
Old Jul 12, 2010 | 01:45 PM
reckleys's Avatar
sorry bout the pics....... I did notice that it does appear to have an electric choke (pretty sure that it's not working)
