Falcon ATV w/electrical issues (plus more)
Old Oct 14, 2010 | 05:35 PM
polaraman's Avatar
Default Falcon ATV w/electrical issues (plus more)
I just bought a nice looking non running Falcon 110c ATV for $150. I put air in the tires, replaced the spark plug, tightened the chain, bought a battery and viola, i have a REALLY nice running ATV for less than $200.
However, I have a few gremlins that are driving me a little crazy. The previous owner replaced the keyswitch and for some reason, none of the electronics work. I even have to crank it by arcing the voltage regulator. The lights don't work, the horn doesn't work.... none of that,. The one thing that does work is the kill button. I can turn off the key and it still runs. I can hit the kill button and it does turn it off. Any ideas?
Also, i noticed today that the four bolts that mount the motor to the frame are GONE. anyone know what size bolts i need to use to correct that?
Old Oct 14, 2010 | 07:26 PM
Jaster94's Avatar
Default your quad
just replace the key switch or see if it looks like the original if possible. here's a hyperlink for parts to look at .
Falcon 110cc Electrical Parts - Parts for Chinese ATVs, Go Karts and Scooters - BuyATVsOnline.com
arcing the regulator? you must be talking about the solenoid. you'll see it also on that hyperlink. i guess you traced the wires for the key switch to see if he was creative on the wiring? as far as horn and lights, have you traced the wiring out to check the connections under the handlebars to make sure they're tight or have been modified and not making a good connection?
on this website, scroll down and look on the left menu bar and you'll see kazuma and a bunch of other brands parts selection/categories. click and happy shopping, as far as bolts, you may just call the website or see what fits and go from there from your local auto parts store......
Falcon 110cc Engine Parts - Parts for Chinese ATVs, Go Karts and Scooters - BuyATVsOnline.com
or, someone out here knows the exact size of the bolts. just trying to help, i'm no master electrician, just a shadetree.........
Old Oct 15, 2010 | 03:52 AM
polaraman's Avatar
The key switch looks original. It plugs into the factory harness (6 prongs). As far as the wiring, it looks completely original. I don't see any backyard wiring issues.
While reading the forums, i read that someone had an issue cranking his ATV because the handbrake safety switch was messed up. Do you have to hold the handbrake down to crank?
Also, how do you check the oil? there's not a stick right? how do you know when you need to add? how many quarts does it take?
Old Oct 15, 2010 | 07:12 AM
Jaster94's Avatar
Default your quad
the brake switch should have to make. probably need to test wiring to check for shorts on key switch. if you don't have a dipstick, there should be a sightglass on the side of the crankcase to look through to check oil level. it doesn't take that much, but i don't know the specs. i'll try to look up capacities for you and get back with you.
Old Oct 15, 2010 | 08:37 AM
polaraman's Avatar
Thank you for much for your help. I"ll try that today and report back.
Where would i find a manual for the Falcon 110c? I bet i could learn so much more if i could find out how it worked instead of me guessing. It took me 2 days to figure out how to shift the gears!
Old Oct 15, 2010 | 08:43 AM
Jaster94's Avatar
here's the download hyperlink for the manual......
Kazuma Falcon 110 ATVs Owners Manual - ATV Trouble Shooters - ATV Knowledgebase - ATV Downloads - ATV Tips and Tricks - ATV News
Old Oct 16, 2010 | 02:21 PM
LynnEdwards's Avatar
Electrical Expert
...The lights don't work, the horn doesn't work.... none of that,. The one thing that does work is the kill button. I can turn off the key and it still runs. I can hit the kill button and it does turn it off. Any ideas?....
Check the main fuse. All the DC power in the quad except the starter motor runs through that fuse (and the ignition switch too). The starter motor path (heavy wires) are not fused, but the control signal that shorts the solenoid terminals togther (like you did manually to get the starter to turn) does come from the fused 12 volt bus. If you find your fuse is good then we can dig deeper with a meter.
Not being able to turn off the quad with the ignition switch is normal behavior for a quad that orignally had a remote control module, and that remote module has since been removed. Does you quad have a remote module? Do you see a loose connector where a remote module may have once been plugged in?
Old Oct 18, 2010 | 04:44 AM
polaraman's Avatar
Sorry i'm just responding. I was riding all weekend!
I got ONE bolt in motor mounts and needed some assistance with the others so i just have that one in it for now. I'll try to finish putting those in this week.
I changed the oil and it looks MUCH better in the sight glass now. It looked tar black before.
I also discovered that i have a pretty bad misfire or skip at WOT. If i back out a little, it runs ok. Any ideas what that may be?
And as for the electrical issues, i have deducted that the whole harness is bad. I may purchase another one.... or i may keep running like it is. So far, i only have $200 invested in it and it's running pretty good.
Old Oct 25, 2010 | 06:17 AM
polaraman's Avatar
I have solved some of my weird electrical issues... sorta. I bought a $9 keyswitch from Advance auto and wired it and I use my ACC as my lights switch. Problem solved!
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
COFatboy
May 2, 2020 12:06 AM
Jenn1
Sep 8, 2015 09:16 AM
WesTech
11
Aug 11, 2015 07:55 AM
Unzzy66
Jul 11, 2015 10:01 PM
