kazuma 150 falcon, turns over wont start
Old Nov 17, 2010 | 10:48 AM
jam1solutions's Avatar
Default kazuma 150 falcon, turns over wont start
this quad will turn over, it has spark, but will not fire at all or start? any sugestions
Old Nov 17, 2010 | 11:53 AM
Jaster94's Avatar
Default your quad
thanks for explaining the "no start". that's good. if it turns over at regular speed(not a low battery) and it has a good spark(how did you test for that?), you need fuel. don't know the history of the quad, but, have you cleaned the carb/jets? have you tried to open the bowl drain screw to see if gas is in the float? after cranking, did you check spark plug for gasoline wetness? is the petcock valve on the bottom of the tank on? is fuel getting to the carb via the hose(did you take hose off to verify fuel flow to carb)? not trying to be Mr. Obvious, but there is fuel in the tank right? make sure the choke is on for cold start, later it will need to be off for warm start. these questions are not designed to question intelligence, merely to relay info to get on the same page and make sure all bases are covered. that way we can get you running.
Old Nov 17, 2010 | 12:02 PM
Fair questions no offense taken!
I checked spark by taking the plug out grounding it and turning it over. Saw good blue spark.
Fuel is in tank and the shut off valve is open, i took the hose off that goes into carb and it does let fuel flow. Then put it back on the carb.
I have not taken the carb apart or anything like that. Plug was dry does not seam to get fuel to it.
The bike will not fire at all, i figure if it got anyfuel it would at least fire. I am not much of a mechanic and never worked on a chinese bike before. But i got to be missing something obvious i feel. Is there a kill switch or anything on these i may be missing?
any ideas please let me know
Old Nov 17, 2010 | 12:06 PM
Jaster94's Avatar
kill switch will kill spark. you got spark. if you have ether/starting fluid, crank the engine and give it a fair squirt, not a lot though, in the airbox/filter. it should run and then die once the fluid is consumed. if it does that, then you need to clean the carb/jets. i'll find a video or a step by step pictorial that will help you do it. we're here to help. thanks.
Old Nov 17, 2010 | 12:21 PM
Jaster94's Avatar
my regular computer is down. when i get it running this afternoon, i'll PM you a pictorial about cleaning your carb/jets. here's one of many videos on how to clean one. be careful. don't lose any parts. pay attention to detail and orientation. the orifices on the jets are critical to get clean. you gotta see daylight through each one of the orifices. that's critical.
YouTube - how to clean a carb (float and jet style)
Old Nov 17, 2010 | 12:34 PM
Jaster94's Avatar
here's a pic of a typical jet. notice the orifices? those have to be so clean so as to see daylight through them. no obstructions whatsoever.
Old Nov 17, 2010 | 06:12 PM
Jaster94's Avatar
scroll down about halfway until you see the mikuni carb that looks familiar and its heading is marked disassembly. follow that. it's self explanatory. obviously reassembly is the opposite steps. this is from ripperds.com.
it's the pictorial.
Disassembly and Cleaning of a Mikuni Round slide Carburetor
Old Jan 14, 2025 | 10:40 AM
dayton24's Avatar
Default Kazuma 150
my kazuma 150 has spark and is getting fuel have sprayed starting fluid into carb and no start what should I do next?
Old Jan 15, 2025 | 04:08 AM
Engines need the right fuel/air mix to start, sometimes starting fluid shoves in too much, or not enough. Clean the carb out, checking float bowl for dirt and water, these will stop the carb from working properly and indicates the tank may need a clean out too. Fit a new plug and do a compression test, less than 90psi indicates something is wrong and makes engines bad to start.
whitty
67
Feb 24, 2021 02:52 PM
MikeyBoyesq
Nov 27, 2020 02:44 PM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
jayking232003
Jun 9, 2015 02:54 PM
1000gade
May 27, 2015 12:37 PM
