Sunl 150cc bog w/ new carb.
Old Dec 4, 2010 | 03:22 PM
jackone's Avatar
Default Sunl 150cc bog w/ new carb.
Got my daughters ATV running Great! Now on to my son's. Took carb off and poured out a tablespoon of dried up fuel. Went to clean and broke off pilot jet in carb. Ordered new carb and replaced on machine. Machine ran good maybe a little rich as plug was black but dry. Accelerated good. Turned off machine and had fuel running out of vent so I bent floats to stop the excess fuel. Machine started but ran rough. Tried mixture screw plus/minus 3/4 turns without any improvment. Runs better with choke on. Will idle but dye with throttle. Need some help. Thanks
Old Dec 4, 2010 | 05:30 PM
Jaster94's Avatar
even on new carbs, whether gasoline or factory crap, solids made it to the jets, i'd recommend cleaning the carb/jets.......
Old Dec 5, 2010 | 09:07 PM
LynnEdwards's Avatar
Electrical Expert
I wonder if the fuel leak was due to crud in the needle seat valve, and now that you adjusted the floats to close fuel off at a lower fuel level the carburetor is now running too lean.
Also, since you've had the carburetor off there may be an air leak. Spray some carburetor cleaner around the idling engine intake manifold area. Any change in engine speed or sound indicates a leak.
dannytas
Sep 26, 2017 06:31 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Sassinm1
Sep 30, 2015 04:23 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
