roketa 110cc
Old Mar 20, 2011 | 10:23 AM
michellebarnard's Avatar
Default roketa 110cc
i have a roketa 110 where can i get a repair manual and buy parts for it , someone told me i can use honda parts. tried to start it now it has no spark can someone help
Old Mar 20, 2011 | 10:05 PM
LynnEdwards's Avatar
Electrical Expert
What is the history of this quad? Did you get it new, and after a lot of running suddenly it doesn't work, or is this quad bought used? Have you ever seen this quad run?
I would just buy chinese replacement parts. Honda dealers aren't going to know if their parts will work or not, plus they're likely to be a little hostile. Besides they will be expensive.
When you say you have no spark, did you pull out the plug, wire it up and hold the thread against the engine while cranking the starter?
Is your CDI a 5 pin CDI or a 4 pin CDI? Check the following pictures:
Old Jul 25, 2012 | 01:27 AM
seanbailey73's Avatar
you may want to check your kill switch, does it have a teather line on it behind the seat to follow beginners I only ask this cause some quads have that kill switchon the back that will go bad and have no spark if so get rid of it and butt connect the two wires together
Bratman2
Aug 6, 2022 01:42 AM
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
wrencher82
Sep 28, 2015 10:02 PM
DanP24
Aug 12, 2015 11:39 AM
