Chinese 110 quad
Old Apr 30, 2011 | 09:11 AM
xXsloth08Xx's Avatar
Default Chinese 110 quad
Hi i have a chinese atv the model number is tpatv03 110 i want to rebuild it how would i go about doing this and what parts would i need?
Old Apr 30, 2011 | 01:13 PM
Mainstreet's Avatar
It would depend on how far you want to go and the condition of your components (crankshaft, cyl head, bore, piston, etc). Are you just looking to rebuild the top end, or a perform a complete overhaul ? A complete overhaul would entail spliting the cases, whereas freshening the top end is a relatively novice task. If you are unfamilair with this type of engine, I highly recommend picking up a Honda E-22 manual such as a Clymers M311 for reference. It covers that engine platform in detail.
Another point to consider, new replacement engines can often be had for a cost comparable to a complete rebuild (depending on the condition of your components and figuring your time has a monetary value). A new engine will include everything except the carb, so your clutch, transmission, starter, stator and other components would all be new again.
If you would like a list of parts needed, a good inspection would be the place to start. From there, I would be happy to help you form a list, or even supply you with a complete engine.
Old Apr 30, 2011 | 07:42 PM
Is there a manual i could find online?
Old Apr 30, 2011 | 10:04 PM
Mainstreet's Avatar
We've always used the factory Honda manual for these engines, so I am not sure what's available online. Someone else may have a suggestion, but we usually recommend the M311 to our customers. You can easily locate the specs for this engine, but if you are in need of more instruction and cannot find a resource, it might be well worth your investment. If you decide the M311 is the way to go, PM me and I'll give you the best deal I can.
Old Apr 30, 2011 | 10:14 PM
LynnEdwards's Avatar
Electrical Expert
I have never seen a full blown engine service manual for the E22 engines available online. GY6 engine service manuals are a different story.
Routine maintenance owners manuals (valve adjustment, clutch adjustment) are available, but engine rebuilding will require the Clymer manual..
Frisky2050
Apr 9, 2020 11:19 AM
Ripinandtearin
1) Engine problems..
Dec 11, 2017 08:06 PM
Waddell4436
Jul 20, 2015 09:46 AM
Ripinandtearin
Jul 19, 2015 08:38 PM
Waddell4436
Technical and How-To Articles
Jul 19, 2015 04:22 PM
