Dinli Diamond back 90cc starter relay assembly
Old May 6, 2011 | 11:13 AM
bunoozy@gmail.com's Avatar
Default Dinli Diamond back 90cc starter relay assembly
Hi,can anyone out ther tell me where I can find a starter relay assembly for the above ATV ???
Old May 6, 2011 | 12:23 PM
ram50's Avatar
You could try here Lifanenginepartswholesale Com - Lifan Parts - Lifan Scooter Parts - Lifan Motorcycle Parts - American they have lots of parts for chinese equipment. If you have your old one you could compare it to the ones they have. They do have a Dinli section but didn's see much in it.
Old May 6, 2011 | 04:44 PM
Default Dinli part
Thank you I will try right now.
Old May 6, 2011 | 11:54 PM
LynnEdwards's Avatar
Electrical Expert
Don't worry too much about getting the *exact* starter solenoid (relay) for your quad. Any quad solenoid will work as long as you can mount it up mechanically. You apply 12 volts to the small wires and the two big terminals get shorted together which makes your starter motor turn. It is as simple as that.
If the small wire connector doesn't match then cut the wires and solder them. The screw terminals should match up OK. It doesn't matter which wire goes where as long as the big wires go to the big screw terminals, and the small wires in the harness go to the small solenoid wires.
One exception: Some quads have the main battery fuse integrated into the solenoid. Instead of the main wiring harness 12 volts coming directly off the battery positive post through an in line fuse, the main wiring harness is fed from the input side of the solenoid which has a fuse built in. You could always just put in a common generic solenoid, and then wire in your own in line fuse off the battery positive terminal. But don't screw up and leave out the fuse . All quads must have a fuse feeding the 12 volt power bus into the wiring harness to prevent fire.
Old May 7, 2011 | 12:41 AM
Mainstreet's Avatar
If you need assistance locating a solenoid, we stock a lot of off brand replacement and performance parts for atvs, go karts, scooters, dirt bikes and utvs. Our website currently shows only brand name components, but once completed, our sister site chinesepartsoutlet.com will display our full inventory. Please feel free to give us a call or send an email if we can help.
tiresharkdbb
Sep 3, 2017 02:06 AM
nature violator
Jul 3, 2015 08:40 PM
jayking232003
Jun 9, 2015 02:54 PM
clsharky
Jun 8, 2015 11:38 AM
leenover
Jun 5, 2015 09:50 PM
