no spark 90CC Monsoon
Old Jun 4, 2011 | 09:25 PM
ts54670's Avatar
Default no spark 90CC Monsoon
i am working on this atv has no spark did start briefly then nothing. I have checked some things just dont no wat values should be I have 12 volts to reg and around 2 volts coming out of it dont no if this should be more??? or should i be lookin other places
Old Jun 6, 2011 | 11:20 PM
LynnEdwards's Avatar
Electrical Expert
Check out this link for a Monsoon diagram. You may have to follow other links in the link to get to the diagram. It is in there somewhere.
http://forums.atvconnection.com/kids...erts-here.html
First look to see if that wiring diagram matches your quad. If it does then get a voltmeter ready and I can walk you through it. The regulator has nothing to do with spark. Having 2 volts output from the regulator may well be a problem, but it is separate from your "no spark" problem.
The ignition system (at least according the the wiring diagram in the link) runs off a moderately high voltage AC supply coming from the stator. There is no 12 volt anything in the ignition system. Get spark first and get the quad running, then tackle the battery charging system. In the mean time keep your battery charged up with a motorcycle battery charger (2 amps maximum charge current).
Last edited by LynnEdwards; Jun 6, 2011 at 11:21 PM. Reason: forgot to add link...
Old Jun 7, 2011 | 09:58 AM
NoLuv4Hoes's Avatar
fordfaithful21
Dec 7, 2015 05:52 PM
Slagpolaris
Sep 5, 2015 09:41 PM
Jason Richards
Sep 4, 2015 06:17 PM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
