Baja 150
Old Jun 23, 2011 | 01:46 PM
  #21
nickd2's Avatar
It stumbles a little bit when I first try to start it. Then it just cranks
Old Jun 23, 2011 | 01:52 PM
  #22
Jaster94's Avatar
i presume you're choking it for a cold start and that sort of stuff. hmmm.. choke assembly working properly inside of carb?
Old Jun 23, 2011 | 01:54 PM
  #23
nickd2's Avatar
To be honest there is no choke which confuses me
Old Jun 23, 2011 | 01:58 PM
  #24
Jaster94's Avatar
ok, maybe LT80, LYNNEDWARDS, or mywifesquad can explain the starter bypass valve function to you. i know a little about it, but not enough to explain it good. hmmm....maybe them guys will chime in on this one again. that's all i can think of for now....
Old Jul 19, 2011 | 08:57 AM
  #25
ricksb143's Avatar
Default same thing
i have the 250cc baja it does the same thing i got a new carb.. it still does the same thing it back fires an bogges down im trying the ignition switch next but cant find the part i posted too so let me me know if you if you find the problem...
Old Jan 30, 2012 | 12:39 PM
  #26
ScottD4577's Avatar
Default Rear axle problems on Baja 150
Originally Posted by Jaster94
have you lifted the rear axle off of the ground via jacks, cinder blocks, or something overhead? then try revving it up and seeing what happens?. i figured a 150cc machine would have reverse, neutral, and forward, not full time automatic like a 50/90cc........
Hi Jasper, My friend is having slippage problems on his Baja 150 rear end. I tried to find a diagram showing the guts to part number BA150-507 (the rear axle assembly) to get the specs on the bearings and whatever else is housed, but I could not find anything. Would greatly appreciate your help.
akguy31
Aug 31, 2019 04:34 AM
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
Chasso
2) Chassis problems..
Sep 19, 2015 03:06 AM
Jul 30, 2015 09:39 AM
