Trans, shaft or diff...
Old Jun 21, 2011 | 03:34 PM
Lefte's Avatar
Default Trans, shaft or diff...
Afternoon everyone!
I was trying to pull a very heavy load and with my wheeler this weekend and now have no forward or backward action. The transmission still shifts, I feel a little bump when it goes into gear, neutral reverse etc. Shifter moves but no movement at all when I release the clutch. Where should I start looking?
Clutch, transmission, rear diff?
Roketa 2 wheel drive 250 cc engine.
Lefte
aka Tom
Old Jun 21, 2011 | 06:53 PM
HMT Racing's Avatar
What type of atv are we talking about? 2wd / 4wd need more info
Old Jun 22, 2011 | 03:20 PM
Lefte's Avatar
As I said in the original post...
Roketa 2 wheel drive, 250 cc
ADD: ATV-2
Lefte
Old Jun 23, 2011 | 07:50 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Id start with the clutch.. but am wondering what kind of rear end this has?... is it the type with the reverse in it?
Old Jun 27, 2011 | 05:30 PM
Lefte's Avatar
Yes it has reverse, I think I'm just going to start tearing parts apart. But since I've never done anything like this, I could have a parts vehicle real quick.
Anyone else have some suggestions?
Lefte
Old Jun 27, 2011 | 06:55 PM
KTM Patrol
Former Chinese POW!
Since the reverse is in the rear end Id take it apart first.
Old Jun 28, 2011 | 01:11 PM
Lefte's Avatar
Sorry I meant to say that yes my gear shifter does have a reverse on it, but none of the gears work...
Old Jun 28, 2011 | 06:51 PM
KTM Patrol
Former Chinese POW!
Did this thing quit pulling while pulling the heavy load? or not work later after pulling the load? Id start by taking the chain off... start the engine and put it in gear... does the engine sprocket turn? if it does.. can you stop its movement with a piece of wood? if you can... you got 1 of 2 things wrong... fried clutch(likely) broken gear shaft(less likely)
Old Jun 28, 2011 | 06:53 PM
Lefte's Avatar
I popped the clutch and loss pull immediately. I didn't hear anything snap though.
Is there a sheer pin in there somewhere?
I was actually thinking the clutch. Shaft drive with a rubber boot from the transmission. I pulled the rubber boot and no turning of the shaft. Are clutches hard to rebuild?
Lefte
Old Jun 28, 2011 | 07:02 PM
KTM Patrol
Former Chinese POW!
There could be a broken key on the crank shaft.. never seen one, but who knows.. weird for a clutch to work and then not work.. but maybe the lining sheared off the plate...
