Engine Surgine on Yamotto
Old Jun 23, 2011 | 02:03 PM
Drewpul's Avatar
Wink Engine Surgine on Yamotto
I just recently put a new engine in my 05 Yamoto. I've tested it out and it runs pretty well. I adjusted the carb to the recommenced settings, and got it to idle. However, sometimes after it idles smoothly for a few minutes, the engine surges. It revs up pretty high, so I turn off the ignition. After a little while of sitting, it starts back up fine.
Is there another adjustment I should be trying???
Thanks
Drew
Old Jun 23, 2011 | 02:57 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Id look for a vacuum leak first... spraying carb cleaner around the carb/manifolds will let you know.. if it does nothing its ok.. if it dies or rpm increases youve got a leak..
Old Jun 23, 2011 | 06:27 PM
LynnEdwards's Avatar
Electrical Expert
Do you have an automatic choke (bystarter valve)?
If you have one of these and it isn't hooked up (or doesn't work) your quad will race and surge at idle after it warms up.
If the connection to the device is intermittent and becomes disconnected, then it will gradually start surging and idling too fast as the bystarter cools and opens the enrichening port back up.
Old Jun 27, 2011 | 08:56 PM
Drewpul's Avatar
It is a manual choke. We can manually adjust it to closed, 1/2 closed, or open. Any other suggestions?
Also, when it does idle down, it idles too low, but we can not see how to adjust the idle.
Any help would be appreciated.
Attachment 5127
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Cummins Driver
Sep 11, 2019 01:22 PM
austinwhitton
Aug 11, 2015 06:21 PM
Jul 30, 2015 09:39 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
