gy6 carb help...please
Old Aug 1, 2011 | 11:22 PM
  #21
LynnEdwards's Avatar
Electrical Expert
Originally Posted by pvillefball421
and how do I know if im getting a spark?
Pull out the spark plug, reconnect it to the plug wire, and hold the plug threads up against the metal engine case.
Turn on the ignition and set all the kill switches to the run position.
Set the brake and crank the starter motor like you were trying to start up the quad.
Do you see spark across the plug gap?
Be sure to keep a good connection between the spark plug threads and the engine or the spark may leap to you instead .
Old Aug 2, 2011 | 06:09 PM
  #22
pvillefball421's Avatar
ive tried everything to get the kick start lined up but to no avail. i cant get the atv started does anyone know of any atv repair stores in ny. i have a local lawnmower shop would that work?
Old Aug 3, 2011 | 11:04 AM
  #23
do i need to remove variator to reassemble the kickstart? if so ill buy an impact wrench then return it
Old Aug 3, 2011 | 11:23 PM
  #24
Electrical Expert
Did you even look at the service manuals in the earlier link?
Old Aug 4, 2011 | 01:23 AM
  #25
ya i did im going to buy an impact wrench to take the variator nut off to make the job a little easier. how does this one look?
Walmart.com: Buffalo Tools Direct DC Electric Impact Wrench: Tools
Old Aug 4, 2011 | 11:36 PM
  #26
Electrical Expert
Not with a ten foot pole...
Where is the maximum torque spec?
Their top listed feature for this item:
"Wrench"
Second top feature listed:
"Material: Steel"
Did you read the one and only review?
Even if you plan on buying it, using it, and then returning it (which is kind of ghetto think in my opinion), you will most likely be wasting your time.
Old Aug 5, 2011 | 01:56 AM
  #27
Ok then maybe I'll buy one from harbor freight tools....
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
