White milky fluid on footboard
Old Nov 12, 2011 | 12:12 PM
pvillefball421's Avatar
Default White milky fluid on footboard
I finally got my quad working and ride able, cheers to me haha. But i noticed today theres a white milky fluid leaking from under the cvt transmission cover. if anyone knows what this could be from please give your advice/ideas thank you as always your a great help. i have a 150cc gy6 motor
Old Nov 14, 2011 | 11:13 PM
bump
Old Nov 15, 2011 | 07:21 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Id pull the cover off and take a look.. only way to get oil in there would be if the engine crank seal was blown or the gear oil in the rear section of it was leaking.. Then you would need some water to make it a milky color.. How much fluid are we talking about?
Old Nov 15, 2011 | 12:36 PM
ya ill take the cover off today to check it out. I'm thinking when i cleaned my quad i used the hose and the tranny cover wasnt bolted on so there was no gasket, do you think this could cause water to mix with the oil to cause the white oil?
Old Nov 16, 2011 | 07:31 AM
KTM Patrol
Former Chinese POW!
If I had to guess.. Id say some oil residue mixed with some water caused the milky fluid.. The cases are vented so they drain out the bottom..
Old Nov 16, 2011 | 09:30 AM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
hmmm-
I used to have a similiar looking "substance" all over my renegae 800x seat
Old Nov 16, 2011 | 10:57 AM
cncpro's Avatar
Originally Posted by beergut
hmmm-
ROFLMFAO!
I just knew when I saw that the last post was from you I knew you were gonna go there. Friggin' sicko, LOL
Pehter
Oct 3, 2024 11:00 PM
Alex G.
Sep 11, 2017 11:38 PM
Whitelx1
Oct 2, 2015 10:55 PM
cboler9
Sep 24, 2015 08:35 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
