Carb
Old Dec 26, 2011 | 12:48 PM
blain's Avatar
Default Carb
Hi guys someone told me to ajust my needle on my carb to solve a red pipe on my 2005 wilderness trail 250 baja and i went to do it today and it don;t have a needle going down throught the top the throttle is on the side. The pump is on the top and the bowl is on the bottom of carb so any ideas what to do on carb to get the red pipe problem gone anyone thank you .
Old Dec 26, 2011 | 05:43 PM
Jaster94's Avatar
it is running lean, you need to richen up the fuel mixture. find the rich/lean mixture screw for your carb. that'll fix it. send pics of your carb to help out. but someone else may have the same quad and can help you identify where it's located. BUT it is running lean.
Old Dec 27, 2011 | 08:30 AM
blain's Avatar
Default carb
thanks i;ll do that
Old Dec 27, 2011 | 02:37 PM
blain's Avatar
Default Carb
I needle was under the pump on top of carb the little clip was two away from bottom slots i put it too the last clip which would raise the needle up i think thats what would give it more fuel or richer am i right.to do that thank you
Old Dec 28, 2011 | 08:15 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
With the clip in the bottom groove you are as rich as you can be without changing to a larger main jet..
Old Dec 28, 2011 | 08:36 AM
blain's Avatar
Default carb
so thats what should take away the red pipe all the time it has.
Old Dec 28, 2011 | 09:51 AM
KTM Patrol
Former Chinese POW!
Depending on how hard you ride you may never get rid of the red pipe.. most are very thin tubing and they get hot.. hot enough to light a cigarette.
Old Dec 28, 2011 | 10:19 AM
blain's Avatar
Default carb
so it will not hurt anything if the pipe is still red some .don;t no much about them just learning as i go
Old Dec 28, 2011 | 11:23 AM
TLC's Avatar
TLC
Two stokes use Slide carbs like this Disassembly and Cleaning of a Mikuni Round slide Carburetor
4 strokes use CV (constant velocity) carbs Constant Velocity carburetor
Here is a tunning guide for them. Basic CV Carburetor Tuning Guide
I only know two people with the Chinese ATVs and both were offered the choice of buying a optional Mikuni carb for a extra $50.
They say its worth it. There ATVs were called Gio.
Old Dec 28, 2011 | 03:02 PM
blain's Avatar
Default carb
thanks for the info
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
