Service Manual E-Ton Yukon
Old Mar 31, 2012 | 05:47 PM
jetennes's Avatar
Default Service Manual E-Ton Yukon
I have a copy of a E-Ton Yukon YXL/CXL service manual. Let me know if you want a copy. I will scan it at your request.
Old Apr 1, 2012 | 01:58 PM
Jaster94's Avatar
sure. sign me up. PM me the details. we'll chit-chat.
Old Apr 7, 2012 | 10:10 PM
jetennes's Avatar
Default Gone for one more week.
I'm on the road one more week. When I get back, I will scan the manual and send you a copy.
Old May 31, 2012 | 12:34 AM
Brian K Epperson Sr.'s Avatar
Default eton yukon manual
Hello, I am working on a eton my son accquired from a friend. He is 10 and very excited about getting it, but it don't run. carb or wiring problem. Could we have a copy of your manual?
thank you for your time.
Old May 31, 2012 | 12:16 PM
Jaster94's Avatar
what is it doing or not doing?
examples: cranks but doesn't start, no spark, spark plug is dry, no fuel in float bowl, runs but bogs down when pushing throttle, etc.....
what size quad? 150cc? 110cc? 90cc? 250cc? automatic transmission, 3 speed transmission, fully manual transmission?
if you list what you know the quad's deficiencies are, we can help you fix it. plus, the manual will help out too!
Old Jun 5, 2012 | 08:52 PM
jetennes's Avatar
I will start scanning the manual this week. Let me know if there is a particular section you require. I can fwd that section to you.
Old Jun 5, 2012 | 08:53 PM
jetennes's Avatar
Old Jun 27, 2012 | 11:27 PM
jetennes's Avatar
Which model E-ton do you have? Here's a link to all the E-ton wiring diagrams.
http://www.anythingatv.com/Technical...g_Diagrams.htm
Old Jun 27, 2012 | 11:33 PM
jetennes's Avatar
So, now I am trying to measure the output of my stator...anyone know what voltage, ohms, amps, AC or DC values for each wire should be on the four wire, six pole E-ton YXL stator? This is because I purchased a new aftermarket CDI for GY6 150 engines...but I'm now not getting any power to the coil from the CDI. Big surprise. I'm now learning some CDI's are for AC system and othewrs are for DC systems. I don't know which I need or how to tell what my systems is. I assume its a DC system but I'm not positive.
Old Jun 27, 2012 | 11:34 PM
jetennes's Avatar
Project X is turning into Project $.
