coil won't stay on Eton Viper 50
Old Apr 24, 2012 | 09:21 PM
bowiesrt8's Avatar
Default coil won't stay on Eton Viper 50
Got a 04' Eton Viper 50 but the ignition coil falls off every time she does a sharp turn. The spark plug is the type that doesn't have a 'tip' just the exposed threads. Is there a trick to help keep it on? Really don't want to spend the bucks on a new coil. Will it hurt anything if I 'crimp' the end of the coil that is supposed to snap on the spark plug?
Old May 23, 2012 | 07:15 AM
Jaster94's Avatar
did you ever find a solution? sorry we missed this post and it fell through the cracks.
Old May 23, 2012 | 08:57 PM
bowiesrt8's Avatar
No still falls off :-( was hoping I'd get some direction.
Old May 23, 2012 | 09:19 PM
Jaster94's Avatar
the end you want to crimp is identical to the naked ones on a lawn mower, ain't it? hmmm....i've crimped them around a spark plug before and left it exposed. you know, no big rubber boot/cover over the spark plug. i'm curious if zip ties or something similiar would work to hold it to the frame. i don't think adhesive backed velcro would work. unsure. . all i can think of is for you to be creative and see what works for installation. does it still have a factory bolt hole left? if so, use a self tapping screw into the frame with lock washers/flat washers or just drill a hole in the frame and a long bolt and double nut the ends. just grasping at straws for you. i am so sorry i can't help on that.
Old May 24, 2012 | 10:55 AM
desjardins2012's Avatar
TAKE A PICTURE AND POST IT i'LL COME UP WITH SOMETHING i JUST BETTER IF i CAN SEE WHAT i'M LOOKING AT..
Old May 24, 2012 | 01:26 PM
Jaster94's Avatar
well for some reason, i can't upload a picture. BUT, i guess i misunderstood your post. i thought the coil pack wasn't staying attached to the frame. i presume it is your coil wire that won't stay attached to the plug. i just peeled back the rubber plug boot on the coil wire and it appears that the metal connection can be crimped to fit on there tighter. hope that helps.
ultangler
Nov 30, 2024 01:35 AM
Joe454
Nov 20, 2020 01:19 PM
Johnny Mac
Aug 15, 2019 03:13 PM
r1pilot83
Sep 27, 2015 07:38 PM
2many2ride
Sep 27, 2015 04:35 AM
