Carb Question Konker sm 200
Old Apr 30, 2012 | 10:49 AM
jeffianson's Avatar
Default Carb Question Konker sm 200
i have a konker sm 200. it lacks power , the plug is white and i am afraid that it may be runing to lean. i can get a dramatic power increse by removing the air box cover but again maybe to lean it has a mukuni carb with the markings 28 1123 and under that 2a 881 can you tell me how to adjust the carb or give me a tip on whether or not i need to re-jet and how the motor is made in a suzuki plant and resembels the dr200 se in fact it takes the same oil filter and spark plug. thanks for yer time and any info would be greatly appritiated
Old Apr 30, 2012 | 10:58 AM
scootergptx's Avatar
Supersock
Hired Gun!
Welcome to the forums.
I have moved your post to a thread of it's own where it should get you more replies.
Old Apr 30, 2012 | 11:39 AM
jeffianson's Avatar
Thanks
Old May 1, 2012 | 08:28 AM
Supersock
Hired Gun!
Most will come a little lean from the factory, just to pass any emission tests.
If it's really white, then you definitely will want to rejet. Not sure on which jet to switch to though. Have you done anything with the exhaust too?
Hopefully we can get someone with a little more experience on this one to chime in.
Old May 2, 2012 | 09:35 AM
jeffianson's Avatar
Default jetting mikuni carb please help
yes the plug is realy white, and yes i have drilled a 3/8" hole in the bafell bike seem to have much more power. i have moved the clip on the needle valve down one and still plug is white the main jet in it is 122.5 i have ordered 125 through 140 any advice would be great . the bike is a konker but it is the same engine as a susuki dr 200se
Old May 2, 2012 | 10:05 AM
Supersock
Hired Gun!
Definitely need the rejet if you opened up both intake and exhaust.
Burn a nice little hole in the piston if you don't.
Old May 3, 2012 | 04:51 PM
jeffianson's Avatar
I have moved the needle up two and i changed the mai jet from 122.5 to a140.0 how do i know that it is right? bike runs great but bot sure if it is jeted right
Jmuddin284
Jan 19, 2026 07:16 AM
200es
Jul 10, 2015 09:09 AM
tweeder
Jul 5, 2015 01:57 PM
yambam13
Jul 4, 2015 01:49 PM
Mikea1978
Jul 4, 2015 12:37 PM
