Looking for Direction Problem Tao Tao 125 ATV
Old Aug 30, 2019 | 03:36 AM
  #31
mwarden's Avatar
I will try that out too. Thanks for the idea. Also, would anyone know roughly how the idle screw and the fuel screw should be set. Have a feeling it may have beeen tampered with as well.
Old Aug 31, 2019 | 04:14 AM
  #32
Idle stop screw doesn't matter until you have it running, because as soon as you give it throttle, it is off the stop. Turn mixture screw all the way in, taking note of how many turns this requires, then out two turns, if doing this doesn't help, screw it back to where it was originally.
Old Aug 31, 2019 | 11:51 AM
  #33
mwarden's Avatar
Great. I will give that a try tonight.
Old Mar 30, 2020 | 12:33 PM
  #34
SandmanSr29's Avatar
Default To the tao tao guy.
Make sure the vacuum then to the tank is working properly and position properly. Also put a new battery in do not use the battery that comes with the bike. Absolutely I cannot say this again do not use the battery that comes with the bike. That is the root of all your evil with these Chinese motorcycles. change the battery and change the fuel lines to American fuel lines. Trust me then this thing will run good
Old Mar 30, 2020 | 12:34 PM
  #35
Put a new battery in it. New American fuel lines that can handle American gas. And spark plug.
no_whereman
Sep 1, 2014 02:16 AM
jakob618
1) Engine problems..
Aug 7, 2014 01:36 PM
bross1004@yahoo.com
May 15, 2013 01:08 PM
bruticus76
8
Nov 10, 2010 11:01 PM
