50 cc chinese atv. lochin motor
Old Jun 4, 2012 | 06:36 PM
irishdad1's Avatar
Default 50cc
Ok sorry it has taken me awhile, I replaced the battery with a new one this weekend, I pulled what I believe is the CDI. It has 4 plug ins on 1 end and that is all.On the side it says GY6125 2007 08 12VAT. I tried to start it after I replaced the battery but still nothing. I checked for a spark again but could not see one this time.
Old Jun 4, 2012 | 06:46 PM
irishdad1's Avatar
I am not sure if this is the CDI or the Stator. where is the cdi located at? I have 4 wires going into this and by looking at another post and the pics he put on, the part I have looks like one of his pics other than the cover over the connectors is black and not white.
Old Jun 4, 2012 | 08:01 PM
irishdad1's Avatar
Default New Insight
I was taking off what I think ws the CDI,( Is the CDI the unit where the spark plug wire goes into)?, if so when I was taking it off the plug wire came out of it and there were no braided strands on it so I cut the sheath back to expose wire and put it back into the boot ( on the unit not the spark plug end ) and then checked for spark and it was sparking like crazy. I tried to start it but no luck, I tried adjusting the air/fuel mixture screw and the idle screw but no luck. Any suggestions? what settings should I have the adjusting screws to? It does have a new plug and I do smell gas?
Old Jun 5, 2012 | 12:07 AM
LynnEdwards's Avatar
Electrical Expert
The spark plug high voltage wire connects to the ignition coil.
Old Jun 5, 2012 | 12:12 AM
  #15
Electrical Expert
Stators are buried inside the engine side cover. You only see the wires to the stator emerging from the engine cover.
CDIs look like this:
Old Jun 5, 2012 | 12:13 AM
  #16
Electrical Expert
Perhaps this is the voltage regulator?
Does it look like this:
Old Jun 5, 2012 | 05:21 PM
  #17
irishdad1's Avatar
Yes that is what it looks like that I thought was the stator. I posted that now I am getting spark after I reconnected the plug wire into the round part that is located directly across from that other part.
Old Jun 6, 2012 | 05:12 PM
  #18
irishdad1's Avatar
I think I found the CDI, It has a 4 pin connector. I am getting spark now that I fixed the plug wire but still no start. I smell fuel and I changed the plug again. Im thinking the settings are not correct. Please Help.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Ripinandtearin
Dec 11, 2017 08:06 PM
DanP24
Aug 12, 2015 11:39 AM
Waddell4436
Jul 20, 2015 09:46 AM
Ripinandtearin
Jul 19, 2015 08:38 PM
