250d Tao Tao and the "click sound"
Old Jul 22, 2012 | 01:30 PM
pakolocho's Avatar
Default 250d Tao Tao and the "click sound"
Hi there, I got a problem with my 250d tao tao, it just won't start, It just make the "click sound" when I push de start button, before that it was working prefectly well, I turn it off and after 30 minutes i tryed it to turn it on, the engine made a couple of intents but then it didn't work, just do the "click sound"... any sugestions??
Old Jul 22, 2012 | 08:02 PM
Jaster94's Avatar
check the voltage of the battery before you do anything. check the voltage while cranking the engine/hitting the starter button. what's the voltage reading while cranking?
if the solenoid still "clicks", then turn the key to the "on" position take a screwdriver and touch the 2 posts together on the solenoid. what did it do? try to crank the engine or just click?
Old Jul 23, 2012 | 10:47 AM
pakolocho's Avatar
I took the screwdriver touching the 2 post of the selenoid and the engine turn on! that means that the selenoid isn't working properly, so I already bought the selenoid online!
Thanks Jaster94!
Old Jul 23, 2012 | 01:31 PM
Jaster94's Avatar
just make sure the battery is charged up. if the voltage gets too low, it won't be enough to engage the solenoid. have a good'en!
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
fordfaithful21
Dec 7, 2015 05:52 PM
kbazzy
Sep 26, 2015 11:26 AM
jsmit116
Sep 18, 2015 10:34 PM
Jersey General
1) Engine problems..
Sep 13, 2015 01:05 PM
