Watch video and help
Old Aug 1, 2012 | 09:26 PM
  #21
ezhoops's Avatar
I sprayed starter fluid where the air filter goes and it stalled. I attached a diagram of my carb.
http://ww2.justanswer.com/uploads/mo...3_gy6_carb.jpg
In the diagram, i Dont have part 29.
But that doesnt seem like it belongs on that jet
Old Aug 2, 2012 | 04:39 AM
  #22
roadiestar's Avatar
part 29 looks like the main jet
Old Aug 2, 2012 | 07:03 AM
  #23
Jaster94's Avatar
some main jets have the extra piece that screws on to it. i know not the technical term or why some have it, but if your jet has threads on the end where it would accommodate a piece like that, it would explain a lot. if not, i would think you either have the wrong microfiche diagram OR someone else has changed the jet to fit the filter/altitude/climate.
Old Aug 2, 2012 | 07:34 AM
  #24
ezhoops's Avatar
There are no threads on top of it.
Old Aug 6, 2012 | 07:46 PM
  #25
ezhoops's Avatar
Tried the plastic bag, torch tip cleaned out carb and still same problem.
How do i figure if its not or getting too much air
Old Aug 7, 2012 | 11:39 AM
  #26
RonV's Avatar
The electric "choke" is easy enough to check. Take it out and get yourself a 12v power source - usually the quad's battery. Note the distance of the needle. Attach the power source - no need to worry about polarity - and watch the needle. It should extend about a 1/2 inch within 5 minutes or so. That needle extends to shut off the extra fuel. It's not really a choke, it's a fuel enrichment valve.
Old Aug 7, 2012 | 11:43 AM
  #27
RonV's Avatar
Part 29 is the main jet and it should be screwed into part 16. Do you have two parts there?
Old Aug 7, 2012 | 12:40 PM
  #28
ezhoops's Avatar
My main jet doesnt have threads for that part.
Will testing the choke kill my battery?
Is there a youtube video how to do it?
Old Aug 7, 2012 | 01:06 PM
  #29
RonV's Avatar
Testing the choke will not kill your battery. I just explained how to do it. Pretty simple.
Can you post a pic of your main jet? I've been in a few of these CV carbs and am concerned about what you are telling me.
Old Aug 7, 2012 | 03:08 PM
  #30
roadiestar's Avatar
Thats how it looks to me. Sounds like he is missing the main jet.
