Watch video and help
Old Aug 7, 2012 | 08:53 PM
  #31
ezhoops's Avatar
Keep in mind that this carb. and atv ran pretty good just 5 months ago with just these jets.
Here is a pic of my jets
Old Aug 7, 2012 | 09:36 PM
  #32
RonV's Avatar
Ok. This guy here is actually two pieces. The main jet unscrews from this. May want to go ahead and do that to make sure your main jet is actually clear.
Old Aug 8, 2012 | 04:29 PM
  #33
ezhoops's Avatar
So what is best way to unscrew it? Gently put it in a vise? Ive never seen it come apart. Is it a common right hand thread?
Old Aug 8, 2012 | 04:38 PM
  #34
RonV's Avatar
The main jet should simply take a flat head screwdriver. Does yours have a slit across the top?
THen, just hold the other part with a wrench. It's got 6 point on the shaft.
Here's what the main jets look like.
Main Jet
Old Aug 10, 2012 | 05:19 PM
  #35
ezhoops's Avatar
Cleaned main jet, no difference.
Vexing because it just ran fine 6 months ago
Old Aug 10, 2012 | 05:44 PM
  #36
RonV's Avatar
Ok, so I found the vid on youtube. It starts and idles, but as soon as you give it gas, it falls on it's face. The jets are clean.
Here's kinda how that carb works. When you give it throttle, the upper diaphram acts off the vaccuum of the motor, and pulls the needle upward. That needle is the one that goes into the cylinder that the main jet screws into. The one you just took apart. If that needle does not move up, then fuel would not be allowed to come up thru the main jet, and it would fall on it's face like that. I would make sure that its put back together properly - the needle should move upward with that diaphram and I would also make sure the diaphram does not have any holes or tears in it. Also, make sure when you put it back together that the top cap seals the diaphram down correctly.
Old Aug 10, 2012 | 06:08 PM
  #37
RonV's Avatar
Oh, and I strongly recommend you adjust your valves, especially if you've never done one on this machine.
I don't know if this video is worth a crap, but just run a search in youtube for a gy6 or 150 valve adjustment.
Old Aug 10, 2012 | 08:20 PM
  #38
ezhoops's Avatar
Thanks ron. Its very hard to tell if needle is moving, it is not adjustable on this carb. Is there some way to test this?
I will try to do the valve adjustment thing.
Please keep the great advice coming
Old Aug 10, 2012 | 08:21 PM
  #39
ezhoops's Avatar
Ron can you post the video about the needle
Old Aug 10, 2012 | 10:14 PM
  #40
RonV's Avatar
Not sure if you can see this, but if you take off your air filter, see if you can see the slide go up when you give it throttle - with it running. The needle pulls up with the slide, but most likely you won't be able to see the needle.
