Tao tao 125d won't move
Old Aug 2, 2012 | 04:59 PM
beaverpilot98's Avatar
Default Tao tao 125d won't move
My son has a Tao Tao 125D, just over a year old.
He has been riding trouble free the last couple weeks, but last night when he went to ride it starts but will not move in either forward or reverse?
I searched forum but haven't relly found this specific problem. Could be clutch but seems strange to fail completely so suddenly.
I have been following the maintenance sched posted by isovapor2112 here:
http://forums.atvconnection.com/chin...ml#post3046969
I changed the engine oil a couple weeks ago and it is full now. Is this il common to clutch or is it a dry set-up? I have not seen anything anywhere about checking or changing trans/clutch oil?
I am out of town so can't check anything right now...just looking for some suggestions.
Thanks
Old Aug 2, 2012 | 05:53 PM
Jaster94's Avatar
now i've never worked on one of these taotaos, so bear with me.....i just looked at one on the web on taotao's website. looks like an automatic/CVT set up. is that right? if so, is the belt broken? have you checked the shifting forks? how about the rod linkages from the shifter handle down to the tranny/gearbox? did it sound like it was engaging in gear? could the brakes be locked up preventing movement? just a few thoughts and once again, i am sorry if these are shots in the dark as i know not about your quad, i have never even seen one of these in person. just the other brands.
Old Aug 3, 2012 | 06:11 AM
Thanks for replying
It's chain drive and from what I've read it's a clutch set-up but I could be wrong. It has a gear selector for F/N/R so I'll be checking that and the brakes as well. I'm just going off reports from the wife at the moment so we'll see what's up when I get a chance to look at it. I thought someone here might have had the same trouble....
Old Aug 3, 2012 | 07:53 PM
Turns out it was a stripped drive sprocket on the output shaft
Old Aug 4, 2012 | 07:45 PM
Jaster94's Avatar
bonus! quick, easy, cheap fix!
Old Jun 20, 2015 | 06:24 PM
Stormer43's Avatar
I have the same probably now but I don't know anything about atvs
Old Jun 20, 2015 | 06:42 PM
Jaster94's Avatar
What's it doin as opposed to not doin? Please elaborate
Old Jun 20, 2015 | 06:46 PM
Stormer43's Avatar
It will start but won't shift in to forward neutral and reverse only had it for 4 weeks I change the oil and all that but still won't do anything but start
Old Jun 21, 2015 | 12:16 AM
Jaster94's Avatar
Bear with me, I haven't worked on a taotao in at least 3 yrs (since I had one), automatic/cvt right? If so, did you trace out the shifter linkage & make sure it is intact & working? I currently have a hensim that wouldn't shift but the fix was the linkage not actuating adequately so I adjusted the linkages now all works great
Old Jun 21, 2015 | 09:37 AM
MPDano's Avatar
Like what was suggested for the OP and if this is a CVT. There is a belt under a cover (opposite side of chain). Maybe 6 screws or bolts holding it down, this houses the belt, clutch as well as rollers.
The Tao website doesn't help much as far as pics as it only shows the different colors this model comes in.
ATA-125D - TAOTAO USA INC
