Tao Tao 110cc, No spark, diagnosis completed
Old Sep 22, 2020 | 01:11 PM
  #21
Sethzs85's Avatar
Originally Posted by merryman
If you remove the kill switch pin from CDI, the kill witches won't work because you have now disconnected them from CDI, Fairly sure Tao Taos are "earth to kill" so check the wire that you have disconnected, if it is earth to kill, should be earthed with kill switch in kill position and/or with ignition switch in off position, but with these switches both in run position, kill wire should not be earthed.
Thank you for your response. I'm sorry but I'm not 100% following what your saying. Not sure exactly what you are saying I should do to check it. Please explain if you don't mind. Thanks so much
Old Sep 23, 2020 | 02:58 AM
  #22
That kill switch pin you have taken out of the CDI is, as the name suggests, connected to the kill switch and the ignition switch, so if you take it out, the CDI is no longer connected to the kill and ignition switch. You need to find out why the wire to that pin is shorted to earth. Connect an ohm meter between that disconnected wire and earth "if it is earth to kill, should be earthed with kill switch in kill position and/or with ignition switch in off position, but with these switches both in run position, kill wire should notbe earthed."
Bratman2
Aug 6, 2022 01:42 AM
Waddell4436
1) Engine problems..
Jul 20, 2015 09:46 AM
Waddell4436
Technical and How-To Articles
Jul 19, 2015 04:22 PM
Bob Maurice
Jul 14, 2015 09:05 AM
clsharky
Jul 13, 2015 02:07 PM
