cougar 150 wont stay running
Old Sep 24, 2012 | 12:36 PM
bubba143826's Avatar
Default cougar 150 wont stay running
my 150 cougar wont stay running it will run while i give it gas and the longer i run it the longer it will idle without me giving it gas but if it sits too long without giving it gas it starts to make a ch sound evrey 10-20 seconds and will die please help
Old Sep 24, 2012 | 06:28 PM
austinbest's Avatar
With mine (all 5 of them) the jets get very dirty in these carburetors. It is an easy fix if that is the problem. 2 10MM bolts hold on the carb, and a needle at the top you can remove with plyers. take the bowl off the bottom (2 phillips) and clean it out with carb cleaner. If you look at the bottom of the carb you will see 2 brass (gold color) flat head screws. Take one out, take a needle and clean the center and the small holes on the sides, put it back in. Repeat this for the other one. Clean out the needle port (top of the carb) and the beather inlet (where the butterfly is).
When putting the needle back in, the sides with the slots should face the sides of the four wheeler, the black piece should slide all the way into the carb with no force so it can screw back on.
Old Sep 24, 2012 | 09:54 PM
Default not the carb
yeah i went through the whole carb thing about 6 months ago and thats the first thing i checked and cleaned even though it was clean i cleaned it so i dont think its the carb im not sure but i ordered the carb rebuild kit the air fuel mix screw the tiny piece of metal on the end is kind of bent and deformed so im gonna try that its got alot of things i have to do to it like it doesnt have a battery i use the kick start to run it, its definitely a work in progress thanks for the input!
whitty
67
Feb 24, 2021 02:52 PM
MikeyBoyesq
Nov 27, 2020 02:44 PM
Dame0927
Oct 29, 2015 10:13 PM
jayking232003
Jun 9, 2015 02:54 PM
blaze_master
May 26, 2015 11:18 AM
