Kazuma Jaguar 500 ignition issue
Old Sep 30, 2012 | 11:12 PM
Rod Verelst's Avatar
Default Kazuma Jaguar 500 ignition issue
Hello. I was hoping someine out there might be able to help with an issue I have with my new Jaguar 500. The bike starts well and runs perfectly and intermitantly will not start. This could be after 1 hour or 4 hours. I sent the CDI unit back as that appeared to have failed. I put the new one in and away it went again. After about 1 hours riding it did the same again. It would turn over but not start. I checked the spark and it had none (new plug). About an hor later it started no issues. I rode it for another couple of hours and once again no spark. I bought another CDI unit and when it arrived rode the bike and when finaly it wouldn't start I changed the CDI unit with the brand new one and it still didn't start ?? I winched it back onto the trailer and gave it one more try and away it went. Can anyone shed some light on this gremlin. Thanks Rod.
Old Oct 1, 2012 | 06:11 AM
Jaster94's Avatar
on your quick connects, check the wiring coming out of the stator and then the one that plugs into your CDI. use the pull/tug method. sometimes, even new ones, the little connectors inside the plastic quick connect, become loose and back out a little bit.
Old Oct 1, 2012 | 04:29 PM
Thanks for that. I have checked the connections on the CDI unit and they look fine. I have ordered a new Stator and regulator, they should be with me this week. I am not sure I am not getting voltage spikes as well as the first CDI unit was fried ??? What do you think?
Jmuddin284
Jan 19, 2026 07:16 AM
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
skinnyr6
Aug 25, 2023 02:18 AM
Unzzy66
Jul 11, 2015 10:01 PM
Albertascramblerx
Jul 8, 2015 11:56 PM
