Anyone have a Kazuma Cougar 250? Need a wiring question answered.
Old Oct 2, 2012 | 05:51 PM
weedmonke's Avatar
Default Anyone have a Kazuma Cougar 250? Need a wiring question answered.
So I've been troubleshooting the ignition on my 2002 Kazuma Cougar 250 and came across something I'm really unsure of...The 2 pin plug on the cdi module appears to have the wires in the wrong places according to any CDI module pinout I have been able to locate (thanks LynnEdwards for the diagrams).
My CDI wiring harness has the stator power wire next to the coil output on the 4 pin connector, and the kill switch wire next to the ground wires on the 4 pin plug. the plug doesnt fit the other way, so if they are wrong, someone put them like that. I don't know the history of the machine, does anyone have a Cougar 250 they can look at their harness and help me out?
As always, Thanks in advance.
Old Oct 3, 2012 | 05:48 PM
LynnEdwards's Avatar
Electrical Expert
I don't know anything about this quad, but here are a couple links that may prove useful:
http://forums.atvconnection.com/chinese-quads-ask-expert/346475-kazuma-250cc-cougar-spark-ignition-issue.html
http://forums.atvconnection.com/chinese-quads/340145-lifan-250cc-dinosaur.html
In the latter link if you scroll down far enough there is a hand drawn wiring diagram by "Resourcefull" on July 1, 2012 showing his ZEI 250cc twin cyllinder engine is wired up. Yours is likely the same. It is different than the single output 6 pin CDI wiring, and different than the wiring you describe.
The wiring diagram may be a bit hard to follow unless you keep this in mind:
1) The CDI dual coil drive outputs (upper left) go to unlabeled connectors. The mating plugs to those connectors are shown on the right edge about 1/4 the way down the page. The connectors go to the two ignition coils.
2) The stator timing/trigger wire goes to another unlabled connector over on the right hand side (brn and grn wires). The CDI trigger input go to an unlabled connector at the top of the page (brn/wht and grn/wht). Those two connectors plug together.
Old Oct 3, 2012 | 10:27 PM
weedmonke's Avatar
Thanks for your reply LynnEdwards. I used your troubleshooting guide from another post and found an open ground for the trigger pulse generator in a 2 wire plug in the wiring harness. I've repaired that and am now able to see spark at both ignition coils. I connected the plugs and gave a shot of starting fluid to the throat of the carb, but was still unable to get the engine to fire ( the carb and tank are dry) Am I correct in thinking that I should get a few fires out of it with a shot of ether, or should I fill the tank and float bowl before assuming I still have a problem?
Thanks for your help.
Cole Hadden
Jun 15, 2025 09:05 AM
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
1966F100
Jul 12, 2015 03:08 AM
tporath
Jul 11, 2015 12:31 PM
D-Hagz
Jul 4, 2015 02:19 AM
