roketa atv help
Old Oct 23, 2012 | 10:58 AM
r0ckinricky's Avatar
Default roketa atv help
Hello my friend gave me a roketa atv to fix all the stickers were ripped off so idk what model it is. is there any way i can find out. also the spark plug broke off inside so i am working on getting that out. and when i try and start it all it does it make a click noise does that mean the starter is dead? thanks
Old Oct 23, 2012 | 11:35 PM
LynnEdwards's Avatar
Electrical Expert
Originally Posted by r0ckinricky
... also the spark plug broke off inside so i am working on getting that out....
I'm having real trouble imagining this...
Spark plug broke off inside where? Inside the cylinder? I'm confused...
Old Oct 24, 2012 | 06:05 AM
no it snapped at the ceramic part i can get it out with a screw extractor i just dont wanna spend the money and time if i cant get the bike to at least turn over
Old Oct 24, 2012 | 11:07 PM
Electrical Expert
I'm still confused on the plug. If the ceramic bit is broken off that doesn't affect the hex sided base of the plug below the ceramic. Plugs are removed with a deep well socket that grabs the hex base of the plug. Whether the ceramic is there or not shouldn't make any difference. Somehow I think using an easy out is a bad idea and a recipe for disaster.
On your starter cranking issue: First try jumping the quad battery to your car using jumper cables (but take great care to get the polarity right). Does the starter turn any better?
If not you'll need a meter. Set it to measure DC volts on the 20 volt DC scale. Measure the voltage right on the battery terminals (plus and minus) while you are attempting to start the quad (as in the solenoid is "clicked" in). What voltage do you measure?
Then move the meter leads to the start motor itself. Red lead on the starter motor input post. Black lead goes to the starter motor case. Dig the probe in to make a good connection. Measure the cranking voltage again (while the solenoid is clicked in and the starter isn't turning). What voltage do you measure?
This will give enough info to determine which course to follow from here. This will determine if your battery is up to snuff, and if your starter motor is getting enough voltage to make it turn.
Old Oct 27, 2012 | 01:59 PM
so i just tested it the battery is at 12 volts and when i press the button it makes a clicking noise and drops down to around 6 volts also did some models not have a kick start ?
Old Oct 27, 2012 | 09:57 PM
Electrical Expert
Your battery is bad or discharged. End of story there...
Surely you can come up with some jumper cables to do the obvious next test... .
Old Oct 28, 2012 | 08:35 AM
i tried hooking a battery charger with 10 amps to the battery while connected but same thing
Old Nov 1, 2012 | 10:28 PM
Electrical Expert
As I would expect. Your starter draws 30 amps or more.
Do the jumper cable test!
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
balanis03
Nov 16, 2011 07:12 AM
Flyby
Jun 13, 2008 05:54 AM
9kids
Aug 2, 2006 10:26 PM
