200cc cdi blow up
Old Apr 5, 2013 | 11:21 AM
bigmoney's Avatar
Default 200cc cdi blow up
ok so my cdi blow up on my aeon cobre 220 when put a brand new one on test all my lights then i tried a spark test and i push the kick my hand slowly and all of a sudden i see a huge smoke cloud i look over the cdi melted a small hole in it
what caused this
what do i test
what do i replace
what do i do
plz help asap
Old Apr 6, 2013 | 10:28 PM
mudmike's Avatar
Your wording is confusing which of these do you mean?
1)I had my cdi off the bike and when I reinstalled it poof it faild spectacularly
2) My original cdi just quit working all of a sudden and when I replaced it the new one faild spectacularly.
3) I tried replacing my stock cdi with a performance part and the new part was an epic fail.
3 is probably due to wrong part (ie. DC cdi on a bike that shoulda been AC)
1 is probably a grounded wire somewhere
2 is a f!@#ing headache but needs resolved
Old Apr 7, 2013 | 10:04 PM
bigmoney's Avatar
number 2 i put a new cdi on and hit the ignition switch it was good then i start to test for spark iand then it just started smoking what do u think
Old Apr 7, 2013 | 10:06 PM
bigmoney's Avatar
also it a aeon cobra 220 200cc. do u know if this is ac or dc cdi
Old Apr 7, 2013 | 11:40 PM
mudmike's Avatar
How many pins on cdi? If it is a six pin (will have a square connector with 4 and another connector with 2 beside it) then LynnEdwards has a good way to check if is AC or DC. He went over the process in the how to diagnose stator stickey at the top of the forum.
Old Apr 8, 2013 | 10:11 AM
bigmoney's Avatar
it a six pin
can post a link to that post
should i just get a dc one
Old Apr 12, 2013 | 12:13 PM
bigmoney's Avatar
ok so i test the innput to the cdi and when i test the ac ingintion pin to the ground pin on the wire harness i set the meter to dc and i get 12 volts then i test it on ac and i get about 24 volt so wat cdi should i get for my quad
Old Apr 12, 2013 | 05:46 PM
bigmoney's Avatar
also i but 2 new cdis on the quad and both got heated and burn a hole in the same place on both cdi i put to ac cdi on it so want the promblem
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
01ssls1
Sep 22, 2015 06:50 AM
01ssls1
3) General Discussions..
Sep 21, 2015 12:23 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
