New guy here , need a little help
Old May 10, 2013 | 09:14 AM
  #71
vulgarwolf's Avatar
its not rubber, its a plastic fitting, take note of which way it comes out
Old May 10, 2013 | 07:40 PM
  #72
NRXTM's Avatar
Cleaned the carb today and now it runs great , the idler jet was almost completely blocked with stuff inside , took a thin wire and cleaned it out. at first it ran like full throttle without pressing gas , was kinda scary . then i loosened the adjuster screw until the wheels barely moved. so im almost done and want to thank you 2 guys , couldn't have done it without you. and thanks again vulgerwolf for convincing me not to sell it.I will upload a video of it running after I get a battery , brake lever , and new filter . also will i need a battery charger or do these have alternators to charge it?
Old May 10, 2013 | 10:08 PM
  #73
Jaster94's Avatar
alternator=stator. yes you have a stator. it's the atv's version of an alternator.
Old May 10, 2013 | 10:13 PM
  #74
NRXTM's Avatar
So no need for battery charger right? And how can i make sure i dont have gas in oil?
Old May 10, 2013 | 10:21 PM
  #75
Jaster94's Avatar
battery chargers are good for when the battery is run down and you're charging it back up overnight or whenever from sitting a while. the battery at rest should be around 12-12.6 volts static. when quad is idling, it ought to be about 12.6-13 volts. when revved up, it should be around 14 volts. measure this with your ohm meter/voltmeter across the battery terminals. set the meter to low voltage AC. red lead on positive and black lead on negative. then it'll read the stator output. a battery charger is for maintenance. stator is for "on the run".
Old May 10, 2013 | 11:52 PM
  #76
vulgarwolf's Avatar
I replaced the stator in mine today and now the damn thing wont start, time to put the tools down and pick the can up
Old May 11, 2013 | 08:11 AM
  #77
NRXTM's Avatar
that sucks , and i guess i wont need a charger
Old May 11, 2013 | 08:53 PM
  #78
Jaster94's Avatar
is the trigger pick up working? is the magnet clean?
Old May 11, 2013 | 08:55 PM
  #79
NRXTM's Avatar
I dont know what either those are :/
Old May 11, 2013 | 09:08 PM
  #80
NRXTM's Avatar
Are those somethings of the stator?
