SunL Information Needed
Old May 26, 2013 | 06:10 PM
dix39's Avatar
Default SunL Information Needed
Hello,
We have a sixteen year old boy in our neighborhood who bought a non-running atv about a week ago. It seems to be my responsibility to make it go again.
From the information I've gathered it appears to be either a 150 or 200 cc SunL Rapidity, engine number DJ164FML, VIN number L5CAELLC36000509. Can anyone decipher either of these, or give me a link to where I can find the information?
At the present I'm looking for the reason there is no spark. It has a 6 pin CDI and I plan to run the test series provided by Lynn Edwards tomorrow, thank you very much sir.
Is there a service manual available for this machine?
Thanks a bunch,
Steve D
Old May 26, 2013 | 07:04 PM
Jaster94's Avatar
if you're following Lynn's advice, you'll get there quick. first thing i'd try is a new spark plug then start checking the quick connects in/out of the stator, CDI, Regulator, coil. but really, the very first place i'd check is the kill switches on the left handlebar slider switch and then the one at the key. those are the usual suspects.
Old May 26, 2013 | 07:31 PM
dix39's Avatar
I seem to remember reading that if I disconnect the kill switch at the CDI it will eliminate that possibility. Is this correct, and will the machine start with this disconnected if that is the problem?
Thanks,
Steve D
Old May 26, 2013 | 07:35 PM
Jaster94's Avatar
I believe so but you may not be able to kill it unless you starve it for fuel with your petcock valve.
Old May 26, 2013 | 07:39 PM
dix39's Avatar
OK, thanks Jasper.
Steve D
Old May 27, 2013 | 12:02 PM
dix39's Avatar
First, I'm sorry I misspelled your name, Jaster, in my last post.
I unplugged the kill switch, but the engine still wouldn't start. Then I used used Lynn's test sequence to determine that the CDI was AC. While doing this I noticed there was only one ground wire going to the 4 pin plug where Lynn shows two. It was adjacent to the ignition coil pin. Do I need to add a ground adjacent to the ignition trigger pulse pin? I didn't notice any loose ground wires hanging from the harness.
Thanks,
Steve D
Old Apr 3, 2018 | 01:50 PM
Nathan Fifield's Avatar
Default Chinese atv engine rebuild
hi I have a Chinese fourwheeler I believe it's the Lifan 200cc but it a 4 speed r-n-1-2-3-4 and I'm trying to rebuild but can't find solid info on what kind and size it is it is air cooled
Old Apr 4, 2018 | 02:32 AM
Start a new thread, jumping into a 5 year old one about something totally different is just annoying.
Put some photos of it up, clear side views, and clear ones of the engine. Find engine number and VIN numbers if you can.
Bigredjeep
Apr 10, 2020 02:55 AM
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
Evan d
Jul 7, 2015 02:36 PM
sticky123
1) Engine problems..
Jun 14, 2015 07:36 AM
