No reverse in 110 ATV
Old Jul 11, 2013 | 11:47 AM
rhensonsr's Avatar
Default No reverse in 110 ATV
The forward gear works and the shifter will go to the reverse position but when given gas, there is no pull. Any suggestions?
Thanks,
Randel
Old Jul 12, 2013 | 06:28 AM
Jaster94's Avatar
follow the shifting mechanism down to the gearbox and see if there's any adjustment linkage on there. if not, watch the mechanism stroke to reverse and listen/feel it. hopefully you don't have an internal issue. you may try disconnecting the mechanism and using a wrench or your hand and see if you can put it in reverse that a way.
Old Jul 20, 2013 | 05:03 PM
rhensonsr's Avatar
Default Hey Jaster,
Thanks for the reply. It has a CVT. The shifter is not slipping on the shaft. I can also feel the three positions as I move the shifter.
Thanks,
Randel
Old Jul 21, 2013 | 09:04 AM
Jaster94's Avatar
wow,,,,so you can feel the 3 positions of the shifter and all looks normal? if so, it may be inside of the shifting cluster. I'll PM you something.
lonerider856
Oct 13, 2023 03:45 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
poutlaw525
Sep 9, 2015 03:19 AM
