eton 50 top speed
Old Aug 5, 2013 | 10:39 PM
PhenomXtreme's Avatar
Default eton 50 top speed
ive been riding my eton 50 pretty hard the past few days, im impressed by its performance. gets up pretty quick but even with no rev limiter the top speed leaves a little to be desired. i contemplated putting different sprockets on (i can easily salvage a set from one of our local salvage yards here) but the way it takes off makes me think otherwise. when i go to take off itll act like its about to go in a high gear (or if it was in a high gear if it had multiple gears), then the rpm will raise a substantial amount, then it will continue at that same level till the rpm tops out. is there a way (hopefully cheap and not too complex) to modify the transmission to increase the top speed? if so how would i go about doing it (id need a fairly good walkthrough lol im still learning about atvs) all help is greatly appreciated
Old Aug 6, 2013 | 07:17 AM
Jaster94's Avatar
the kiddie quads, like your 50cc Eton, is a CVT driven gearbox. i don't know of any mods for the tranny other than the output shaft's sprocket. i don't think there are any internal mods. of course the rear sprocket can be changed out and then change the size of tires you have. good luck
Old Aug 6, 2013 | 07:28 AM
LT80's Avatar
LT80 Expert
How about doing clutch maintenance to make sure all is well in there.
There are plenty of speed goodies for scooter motors. Call Hetrick Racing.
FYI: Eton is a finely made Tiawanese machine (not china).
Old Aug 6, 2013 | 09:52 AM
Ah thank you very much ill have to give em a call
Pehter
Oct 3, 2024 11:00 PM
ReconBayou
Sep 23, 2015 02:41 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
Minimod
Sep 10, 2015 09:20 PM
Minimod
Sep 10, 2015 08:03 AM
