Bashan Blue and White Smoke When hot
Old Aug 25, 2013 | 03:36 PM
  #21
Jaster94's Avatar
your compression would be adequate, but you more than likely would have more than normal blowby.
Old Aug 26, 2013 | 03:33 AM
  #22
leerx7rsuk's Avatar
I take it blowby means compression running past the rings into the crankcase a little.. Sorry im a total newbie..Will it burn oil though
Old Aug 28, 2013 | 07:15 AM
  #23
brumbear's Avatar
Sorry for the late reply I have been crazy at work. I see you bought the big bore kit!! The cyl. being scored is a write off if you cant bore it, weather you feel it or not add the heat and pressure of a running motor and viola grenade primed IMHO you made the right choice.
Pehter
Oct 3, 2024 11:00 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
