LINHAI Rustler 300
Old Oct 17, 2013 | 08:25 AM
zebraas's Avatar
Default LINHAI Rustler 300
Hi. I am new to forum. I own a 300 Rustler Linhai. 720 miles in clock. It s a 2007 model, i do not ride it a lot. 1)It does nt want to idle, I used carb cleaner, and also took of carb and clean it. But still will not idle? 2) The weekend I pressure cleaned it and now when switch to reverse it jerks and stalls (sounds like back fire)
What can be the problem
Old Oct 17, 2013 | 06:16 PM
Jaster94's Avatar
So you pulled & cleaned the jets in the carb, right? Power washing like opt said does strange things to the electrical system, sometimes you just let it dry out
Old Oct 18, 2013 | 05:55 AM
zebraas's Avatar
Hi the idle problem has been for a long time, I do nt ride it a lot. Then when I power wash it now it stalls and backfires when reversing . But forward all 100% How do the reverse function? Is there wires that could be loose or something else???
Old Oct 18, 2013 | 10:04 AM
Jaster94's Avatar
I used to have a linhai 300cc & I can't remember if it had a reverse limiter on it or not
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
zebraas
Dec 11, 2013 12:55 PM
zebraas
Oct 17, 2013 04:01 PM
TheWiking
May 19, 2006 07:59 PM
