Coolster 125 ATV leaking gas from bottom of engine.
Old Dec 27, 2013 | 04:33 PM
holnugget's Avatar
Default Coolster 125 ATV leaking gas from bottom of engine.
I just bought a brand new Coolster 125 ATV for my son and when I turned on the gas valve it started leaking gas out of the bottom of the ATV. It was not a small leak but a big leak. When I turn off the valve it stops. This is a brand new ATV and can't believe my luck. The company I bought it from won't return calls and emails and there are no authorized retailers in my area. Does anyone have any simple trouble shooting suggestions. Thanks.
Old Dec 28, 2013 | 09:47 AM
Zrock's Avatar
Super Quad Patrol
Is it coming from the fuel bowl drain tube off the carb? its run down below the engine. Their may be a little screw used for draining the fuel bowl that may have not been tightened. It will be right above where the tube is on the bottom of the fuel bowl. You could also have a stuck float in the carb and its coming out the overflow. Give the carb a few light taps with a screwdriver and see if it stops.
Old Dec 28, 2013 | 11:09 AM
brumbear's Avatar
stuck float valve +1
ReconBayou
Oct 31, 2022 05:37 PM
Joe454
Nov 20, 2020 01:19 PM
badgerboy1
Sep 26, 2017 06:11 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
