Tao tao 150cc atv grinding
Old Jul 11, 2014 | 04:03 PM
xxMrUknoWHOxx's Avatar
Default Tao tao 150cc atv grinding
I recently purchased a Tao Tao 150cc atv. It hasn't run right since I got it. I finally got it running good for about a day then this started. I was riding today when out of nowhere it started making this loud grinding noise. After playing around with different speeds a little bit it finally stopped. About 5 minutes later it started doing it again and wouldn't stop. I tried just riding it out until it just kept doing it. I came to a small incline where it then just gave out. Any idea what the problem may be?
Also, please be very detailed. I'm new to atvs and don't know much about engines and that.
Old Jul 12, 2014 | 02:43 AM
If it is belt drive, the belt has probably broken. The belt runs from the crankshaft to the "gearbox" in a case. If you don't feel confident to tackle it, get someone who knows about small motorcycle engines to take a look.
Old Jul 12, 2014 | 09:08 AM
Thank you so much! Got the belt replaced and it's running great.
Old Jul 12, 2014 | 11:14 AM
Ran for 5 mins now doing same thing. Help!
Old Jul 12, 2014 | 02:23 PM
Also it doesn't do this in reverse.
Old Jul 13, 2014 | 02:50 AM
The idea was to take a look at the belt, if it was OK your problem is somewhere else. It is starting to look like the gearbox. Again if you don't feel confident to tackle it, get an "expert" to check it over.
flyin-lowe
Dec 1, 2017 03:18 AM
dannytas
Sep 26, 2017 06:31 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
Minimod
Sep 10, 2015 08:03 AM
frostphase
Aug 19, 2015 07:11 PM
