eton viper 90r
Old Sep 30, 2014 | 05:15 PM
timclick's Avatar
Default eton viper 90r
I just bought an eton viper 90r. It was sitting for 2 years. I took apart and cleaned the carb, new battery, fresh gas. Start..no.. No fire..i replaced the regulator, had fire. Now can make it start by shorting starter with screw driver or kick start. Nothin electonic work, lights, horn, starter... Fuse is good... Dont know anything about these atvs...maybe bad cdi, will it start if its bad? Also it will not go into gear, its electric.. Any help appreciated.
Old Oct 1, 2014 | 11:06 AM
scootergptx's Avatar
Supersock
Hired Gun!
Welcome to the forums.
I'm moving this over to a section where you should get more results.
Old Oct 2, 2014 | 01:54 AM
Your problem will probably be the main wire from fuse to ignition switch to lights starter button etc. Could be the switch its self.
flyin-lowe
Dec 1, 2017 03:18 AM
Minimod
Sep 10, 2015 09:20 PM
Minimod
Sep 10, 2015 08:03 AM
Jr Wagner
Aug 21, 2015 07:56 PM
mbkirk
Aug 14, 2015 08:20 PM
