Redcat MPX 150 Problems/Questions
Old Jan 27, 2015 | 07:26 AM
  #41
MPDano's Avatar
Both look fine to me. As long as the brake line fittings are the same and in the same location, your good to go. I put a Yamaha Bear Tracker lever on mine and it looks identical on my Chinese 250 Quad.
Old Jan 27, 2015 | 09:23 AM
  #42
Steve2011's Avatar
Ok I thought they would work also. My concern is the length of the handle or lever. If it's to small that makes a difference on pulling it in to stop and vice versa
Old Jan 27, 2015 | 10:12 AM
  #43
MPDano's Avatar
You can remove the handle and cut it, then grind it down. I do this whenever I install hand guards on my Dirtbike and ATV's.
Attached Thumbnails Redcat MPX 150 Problems/Questions-gaurds.jpg   Redcat MPX 150 Problems/Questions-ktm-guards.jpg
Old Jan 29, 2015 | 05:50 PM
  #44
Steve2011's Avatar
Ok appreciate the help on that. Could someone please tell me how to get the center caps off of this on the front wheels. Do they pry off or do they twist off?
Old Jan 31, 2015 | 08:25 AM
  #45
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
All of mine are rubber and twist/pry off.
Old Feb 2, 2015 | 11:29 AM
  #46
bdelancy's Avatar
I ordered the entire master cylinder assembly like you have pictured on amazon it was only 17 bucks
Old Feb 2, 2015 | 07:34 PM
  #47
Steve2011's Avatar
Well low and behold I actually got this master cylinder working a little bit. But you have to pump the handle 4 or 5 times for it to get hard. So what do you think? Is it still junk or is that normal? The brake pads are a little worn but not a lot. Where do you get rear pads for this thing? The ones on kazuma and stuff dont look like the ones on the bike.
Old Oct 21, 2024 | 06:33 AM
  #48
Mpx150's Avatar
Default Shift lever
Originally Posted by mywifesquad
If it doesnt pump brake fluid its junk.. No way to remove the piston?
Once you determine the thread size..Id think its a 10 X 1.5 mm (match it up with a metric nut/) Then go to mcmaster.com ... put "metric *****" in the search..
Does anyone know where to get the shift lever? I just got an mpx 150 from a trade in and the shifter is missing. Along with the adapter for the fuel line.
Old Oct 22, 2024 | 02:39 AM
  #49
You can get universal shift levers for ATVs from eBay and Amazon. Check measurements are compatible before buying. Not sure what you mean by adapter for the fuel line. If two pipes are different diameters, an easy dodge is to fit an in line fuel filter that has steps to take different inside dia pipes.
supermanotorious
Mar 12, 2021 11:02 PM
