Starting issues 110cc
Old Mar 23, 2015 | 02:33 PM
renegade83's Avatar
Default Starting issues 110cc
Hello all. Me and my son we out riding when his 110 suddenly died. He cranked and cranked and nothing, had gas so I tried, then it stopped cranking too. There's no clicking or anything when I hit the start button, when I Jump post on the solenoid it spins over but won't start. Checked for spark and I have none (which is probably why it died to begin with). I have juice to starter button, and seem to be getting juice to solenoid. Don't seem to have any loose or broken wires anywhere. Any clues what to check?
Old Mar 27, 2015 | 10:37 AM
ATV_MAN's Avatar
The wiring on these quads is not the best, what I would do is check to make sure nothing has become loose or detached, there are many safety switches that fail easy on these as well. Also the plugs are cheap and can foul easy, if you can remove it and get the number off it you can cross it over to an NGK and replace it which is what I do for Chinese quads that i've repaired.
Old Mar 27, 2015 | 12:31 PM
renegade83's Avatar
Well after doing some searching I decided to remove the safety wire from the CDI, now I have spark but it's a weak one. So I ordered a new coil and spark plug. While I'm at it I'm putting a new filter and fresh oil (definitely overdue). Start button isn't working so I ordered a new solenoid, pretty sure that's what it is. As far as things coming loose I've checked every connection I could find and I couldn't find any loose connections. So hopefully with the new plug, coil, and solenoid it'll fire up.
Old Mar 28, 2015 | 09:43 AM
Zrock's Avatar
Super Quad Patrol
While your waiting for parts i would pull the wire harness or do it on the machine. Find all the junction points under all the tape and re solder them all. I found several on my machine that were coming apart from their poor cold solder joints.
Old Apr 3, 2015 | 04:01 PM
renegade83's Avatar
Will do when I have a little more time, a lot going on this week. Changed spark plug and coil, got a strong spark now. Also put on a new air and fuel filter (needed them), and a new starter solenoid. Still getting nothing when I push the starter button, when I jump the solenoid it'll spin over and I get a strong spark but it won't start. I noticed that there is a short in the key switch, going to order another one. Any chance this could be my problem? I thought as long as I had spark and gas it should run?
Also I checked all connections and I can't find any loose, or broken wires.
Gonna change a couple more things just for the hell of it, parts for this thing is dirt cheap. If changing the ignition switch, cdi, rectifier, and left switch assembly doesn't do it ($23 worth of parts) I'll just bring it to someone to get fixed.
chinkapin
Jul 14, 2016 06:58 AM
Dame0927
Oct 29, 2015 10:13 PM
buckshit
Sep 24, 2015 08:49 PM
kevbowe
Jun 1, 2015 01:17 AM
1000gade
May 27, 2015 12:37 PM
