Need Help getting a 110cc back up and running
Old Nov 19, 2015 | 09:22 PM
MPDano's Avatar
Is this with the spark plug in or out. If in, try removing it and then jump the solenoid. Either flooded cylinder with gas or low battery or both is what the video looks like to me.
Old Nov 19, 2015 | 09:25 PM
DanV97's Avatar
It was plugged in. The volt meter is showing near 12v. How can I fix the flooded cylinder?
Old Nov 19, 2015 | 09:26 PM
MPDano's Avatar
...by removing the spark plug like i said and cranking it over. Oh, and don't put your face near the hole, put a rag or something over it.
Old Nov 19, 2015 | 09:27 PM
DanV97's Avatar
ok, will do that right now.
Old Nov 19, 2015 | 09:36 PM
  #15
DanV97's Avatar
OK after removing the spark plug, I cranked it up again and it started spinning faster for about 3 seconds then slowed down to half turns. I just measured the voltage on the battery and read close to 11v. So now I'll recharge that battery and try cranking it up again to see if starter maintains the spin.
Old Nov 20, 2015 | 11:39 PM
  #16
DanV97's Avatar
Default Great News
I finally got it running, but it stops after about 10 secs. What could be the problem? Gas prob? Do I need to adjust anything on the carb? I can post more detailed pics for the carb, let me know.
Old Nov 22, 2015 | 02:30 PM
  #17
DanV97's Avatar
Got it up and running. Thanks for all the help.
Link to the footage of atv working:
Old Nov 22, 2015 | 06:27 PM
  #18
MPDano's Avatar
How about finishing off your post with the fix that ended up working?
Old Nov 22, 2015 | 06:40 PM
  #19
DanV97's Avatar
Default How I got it running
Put in a new carb and battery. Fixed the starter button issue by installing a custom button. Then opened up the stator and cleaned it out. Finally put it back together and fired it up. Make sure the battery is charged up to 12.6v or it will not turn over. I had to jump the battery with my car many times although it was new battery.
Old Dec 16, 2015 | 02:54 PM
  #20
Oneway8732's Avatar
Default any help would be useful
I need help figuring if an how to bypass this last thing
Attached Thumbnails Need Help getting a 110cc back up and running-1450298831157.jpg
Jersey General
1) Engine problems..
Sep 13, 2015 01:05 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
toonces
Sep 5, 2015 01:14 PM
firsttimerider
Aug 27, 2015 02:09 PM
