110cc - oil level
Old Feb 22, 2016 | 09:39 AM
schildi's Avatar
Default 110cc - oil level
Got a Cheetah on Saturday from a local dealer.
Did the first oil change after an hour of running the engine. Dealer said it takes 3/4 of a quart, but with that amount, it looks overfilled when I look at the dip stick.
How much oil should I be putting in there?
Dealer also said there is no oil filter. I could not find one, but just wanting to confirm that the information I have is correct.
I did try a quick search and looked in the manual with little success.
Thanks a lot for any replies!
Old Feb 22, 2016 | 10:19 AM
Zrock's Avatar
Super Quad Patrol
ya the smaller machines dont have filters. 3/4 sounds about right.. The machine has to be on a level surface as even 1/2" of tilt eater way will make a big difference on your dipstick or sight glass.
Old Feb 22, 2016 | 10:39 AM
schildi's Avatar
Thanks Zrock!
I used standard 10W-40 motorcycle oil, I that what you are putting in?
The Cheetah ran fine on the first day, but I have to say that we saw a good improvement on day 2. Smoother, more responsive throttle, etc.
Took it out on a short trail on day 2. The kid did fine on it. One small issue is a constant squeak now (sounds like it's coming from the rear axle / wheel area), have to pinpoint that and figure out how to fix it. Any ideas on that?
Old Feb 23, 2016 | 09:35 AM
Zrock's Avatar
Super Quad Patrol
i run synth atv/motorcycle oil..
DennisZ
Feb 22, 2016 12:09 PM
schildi
1) Engine problems..
Feb 20, 2016 09:48 AM
Greasemonkey2067
Feb 17, 2016 12:54 PM
