E ton 70 viper problems
Old Feb 26, 2016 | 04:42 PM
admcconn's Avatar
Default E ton 70 viper problems
Just put new carb and air filter on quad. It will idle fine, but when i hit the throttle it dies out. It will run on full choke, but will die out when letting idle. Checked carb before putting on, jets and float all looked good. Any help would be appreciated. Also, have good fuel flow.
Old Feb 27, 2016 | 07:25 AM
LT80's Avatar
LT80 Expert
Welcome to the forums.
I'd check the compression. should be 90+
Old Feb 27, 2016 | 08:37 AM
MPDano's Avatar
runs on choke is clogged or too small idle (slow) jet. Pull the idle jet from your old carb and make sure it is clean and put in your new carb. Verify jet numbers on them an post.
Old Feb 27, 2016 | 09:19 AM
admcconn's Avatar
is there a number stamped on the jets?
Old Feb 27, 2016 | 09:40 AM
LT80's Avatar
LT80 Expert
I considered the new carb cleaned and correctly jetted...yes the jets are numbered. Pilot jets on the side, main jet on the bottom.
Guess we'll see.
FYI: you have yourself a finely made Tiawanese machine.
It's amazing how a lil ocean can separate good machines from less than good..
Last edited by LT80; Feb 27, 2016 at 11:29 AM. Reason: didn't want to offend the chinese community. :)
Old Feb 27, 2016 | 10:49 AM
MPDano's Avatar
Yup. It may be very faint but it's there.
Old Feb 27, 2016 | 11:28 AM
LT80's Avatar
LT80 Expert
Yea! sometimes magnifier on top of magnifier. LOL
Old Feb 27, 2016 | 11:31 AM
MPDano's Avatar
Yup, and with my old eyes. I usually take a pic of it with my phone and zoom in.
Old Feb 27, 2016 | 12:28 PM
admcconn's Avatar
I'll get my magnifing glass out and get back with ya. Thanks for the help.
Old Feb 28, 2016 | 08:44 PM
admcconn's Avatar
Guess we'll see.
Put main jet from old carb into new carb and that did the trick. Quad runs great now. Thanks for the help.
