Dinli 90 Fuel isues
Old Mar 19, 2016 | 08:43 AM
Gflanagan's Avatar
Default Dinli 90 Fuel isues
I'm having some fuel issues with my dinli. When it's sitting and idling I can give it full throttle and it will scream for about two seconds. Then it falls on its face like it is out of fuel. If you let off the throttle it returns to idle. If I let it idle for several seconds I can do it again but if I try to throttle too early then it bogs down. It's getting plenty of fuel from tank. I disconnected fuel line while running and fuel is running out of line at carb great. Thanks in advance guys.
Old Mar 19, 2016 | 09:40 AM
Zrock's Avatar
Super Quad Patrol
i would say time for a carb clean. Or fuel filter replace if it has a inline filter. Sounds like its not getting enough fuel under load
Old Mar 19, 2016 | 11:08 AM
LT80's Avatar
LT80 Expert
ditto..clean the carb. something is plugging the main jet.
Old Mar 19, 2016 | 12:51 PM
Gflanagan's Avatar
Thanks for the replies! I found the issue. I was using an aftermarket air filter an it was not resticting the air enough. I installed the OEM filter and it screams now!
rjarnold1987
Dec 25, 2019 07:05 AM
JD11
Mar 27, 2016 08:26 PM
Dewey Christensen
Mar 24, 2016 01:05 PM
Swatj15
Mar 18, 2016 04:51 AM
manxman
Mar 13, 2016 05:42 PM
